test
Page 56 of 81 FirstFirst ... 64652535455565758596066 ... LastLast
Results 1,101 to 1,120 of 1618
Thread: Avanza Periodic Maintenance Service (PMS)
  1. #1101
    Join Date
    Default Re: Avanza Periodic Maintenance Service (PMS)
    Quote Originally Posted by dreamer21 View Post
    sir jojo, ask ko lang papano mo nilayan ng takip yung binutas so you could insert yung cabin filter... kasi nung natanong ako sa casa even if walang tray basta mayroon pantakip duon sa bubutasing part is ok lang, just like sa mga innova.
    sir, sa denso e. rodriguez, q.c. pwede magpalagay cabin filter P1,200 look for jordan
  2. #1102
    Join Date
    May 2010
    Quote Originally Posted by rbmjr_27 View Post
    thanks for the info ill keep that in mind, pag may lakas na ako pumunta (or maybe after na ma expire warranty ko para sabay sabay na pagbili ng accessories) ng manila sir. hehehhehe
    im for tarlac pa, two tyt dealership na pinagtanungan ko e parang wala silang idea sa orig parts ng cabin filter....
    sir jojo, ill probably do that when my warranty expire, masyado kasi mahigpit mga dealership dito sa warranty ni ultimo magwheel may mavovoid daw.
  3. #1103
    Join Date
    kunsabagay, maintain mo nalang na malinis ang flooring/mat especially sa bandang passenger side(front) para di mahigop ng AC fan, iwasan mo din na mabuksan ang air vent na galing sa labas...and as much as possible, hwag kang bubukas ng window during dry(dusty) season.
  4. #1104
    Join Date
    Oct 2007
    Quote Originally Posted by xda2jojo View Post
    Minsan pag sinumpong ako ng kakuriputan pag ka maalikabok like rough road pinapatay ko a/c tiis ko nalang init
  5. #1105
    Join Date
    Jun 2008
    Blue LED ang ginamit? Parang medyo greenish.
    oo nga no.. hehe.. di ko alam.
  6. #1106
    Join Date
    white bulbs yun sir, talagang green ang color
  7. #1107
    Join Date
    nice one sir, madali lang ba baklasin yung panel at palitan ng ilaw? balak ko din kasi palitan yung ilaw ng instrument panel..thanks mga sir.
  8. #1108
    Join Date
    Quote Originally Posted by arki69 View Post
    sir, madali lang magbaklas ang mahirap ikabit ulit yung rpm cable sakto lang kasi ang haba nito
  9. #1109
    Join Date
    natatakot kasi akong baklasin baka may mabaling mga plastic clips sa loob at di lumapat pagibinalik....meron bang step by step procedure dito yung mga do's and dont's...thanks sa info sir rbmj
  10. #1110
    Join Date
    Mga sir, lapit na ko mag-60km. Hingi lang ako idea/estimates sa 60km PMS. Appreciate your inputs. Thanks.
  11. #1111
    Join Date
    Aug 2005
    Quote Originally Posted by tonying.321 View Post
    basically the same lang as your 50,000 km PMS. kaso every 20,000 km ang aircon maintenance. so kung pinagawa mo ito noong 40,000 km PMS, due na.
  12. #1112
    Join Date
    thank you sir for the info.
  13. #1113
    Join Date
    Aug 2005
    Bukas, magpapa 80,000 km PMS ako.
    + change oil
    + change oil filter
    + change brake fluid
    + change PS fluid
    + aircon cleaning
    + brake cleaning
    + inspect spark plugs if for replacement
  14. #1114
    Join Date
    Aug 2009
    Help naman po. I'm not sure if ok lang to i-post dito sa PMS thread.
    Bigla kasing hindi na nag ON yung AirCon ng avanza ko. Kahit fan lang ayaw mag ON. Pero yung sa likod nag oON naman hindi nga lang ganun ka-lamig. Meron na po bang naka experience nito sa inyo? Kapag dinala ko ba sa casa to ano ba pede ko i-expect especially sa mga babayaran para icheck yung problem? Mag 30K palang ODO reading ko may problema na AC ko huhuhu!
    Thanks po.
  15. #1115
    Join Date
    Aug 2005
    ^^^ possible na busted lang ang fuse.
    since naka 30,000 km kana, sana mayroon kang aircon maintenance, if not, baka hindi i-honor ang warranty kung may piyesa na nasira.
    paki balitaan na lang po kami. TIA.
  16. #1116
    Join Date
    Aug 2009
    ^^sige po. Salamat. patay ako hindi pa ko nakakapag AC Maintenance
  17. #1117
    Join Date
    Nov 2006
    Quote Originally Posted by jh3ff View Post
    Thanks po.
    Nangyari sa akin yan. Relay ng front blower yung problem. Pwede kong ibalik sa casa after repair from Ondoy kaya lang weeks na naman ang bibilangin dahil sa tagal ng insurance approval. Since out of warranty na, pinagawa ko na lang aircon shop. Inspect lahat, yung relay lang ang problem. Paid P1500 for diagnosis and part replacement. Sa casa sobrang mahal ny price ng mga relay.
  18. #1118
    Join Date
    every 40k km naman ata ang a/c maintenance...(tama ba?) kaya pasok ka pa kahit di ka pa nakapagpa-a/c cleaning. try mo din i-check fuse.
  19. #1119
    Join Date
    Reminder sa mga nagpapa change oil outside casa, got a call from my wife this morning, dala kasi nya yung avanza going to makati, bigla daw umilaw yung guage ng oil along tunasan munti, mabuti na lang 50 meters away is a petron station. so stop sya sa petron, pero since maaga pa aroung 615am intay pa sya dumating mechanic....per inspection ng mechanic maluwag daw yung oil filter at dun tumagas yung langis....tsk tsk tsk..kakapa-change oil ko lang last monday sa petron daang hari, my bad di ko na dobol check yung oil filter kung talagang nasikipan, nanunuod pa naman ako sa paggawa.....buti na lang at hindi sa SLEX inabutan kundi patay, katok ang makina nag avanza namin
  20. #1120
    Join Date
    Sep 2005
    malamang fuse yan sir.. ganyan yung sa akin dati..
    Thanks po.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
