test
Page 18 of 81 FirstFirst ... 81415161718192021222868 ... LastLast
Results 341 to 360 of 1618
Thread: Avanza Periodic Maintenance Service (PMS)
  1. #341
    Default Re: Avanza Periodic Maintenance Sevice (PMS)
    Quote Originally Posted by juanarodriguez View Post
    Had my 20k pms at TYT SM North
    20km check up 1,484
    change oil (TGMO SL20W-50) mineral oil = 621.08
    change spark plugs=550.24
    replace oil filter=399.86
    rotate tires
    TOTAL DAMAGE 2,688.56 -> less na po dito yung 12% discount for both labor and parts (VIP card holder, cash payment)
    PS: old spark plugs and extra oil binalik po sa akin
    Pinatanggal ko yung wheel alignment/balancing 2,700 petot din yun - standard daw ito for 20k pero I was able to postpone it until next pms.
    Thanks to Shadow and Harryparrot for the advice kung hindi napagawa ko ng di oras yung alignment
    Mam Jane ang laki naman ng na discout nio *12% sa total charges incurred, papano ba maka avail ng VIP card sa Toyota? kaka PMS lang ng esmi ko kay vanzy last week for 20K KM she was charged by Toyota San Fdo. Pamp. for more than 4,500 petot... what do you think? was that a rip off? considering that she lacks that special previlege card..
  2. #342
    Join Date
    Quote Originally Posted by levanz2007 View Post
    Hi sir re VIP card. depende yan sa casa kung nag-ooffer sila. Sa TYT BK ang requirement is nakabili ka sa kanila ng at least 2 cars. However, nakaibigan ko na lang yung mga tao doon kaya nabigyan ako ng card. It pays pag kinaibigan mo mga tao sa casa...nakakapag order nga ako ng parts without deposit pero di ko naman inaabuso yon... pag dating bayad agad para makakaulit ulit!
    Yung orig quote sa akin around 4-5k din for 20k pms kasi kasama ang camber alingment etc na around 2.6k pinatanggal ko iyon kasi advice nila armin at harryparrot kung wala pa namang kabig wag muna. The alignment is however part of the recommended jobs for 20k but I noticed marami ding hindi nag aavail sa atin nito. Low mileage din po ako (for 20k pms ang actual odo ko ay only 16k) plus pure city driving lang. Pwede mo naman ipaidentify lahat ng mga jobs bago simulan ang PMS para magka-idea ka.
    Ako ginawa ko nung nalaman ko na 4-5k ang damage tinext ko na sila armin and harryparrot for advice. Pero talagang part yung alignment na iyon pag 20k.
    Sir post mo dito yung mga ginawa nila including breakdown ng damage.
  3. #343
    Join Date
    Aug 2005
    Nagpa wheel balancing ako noong 20K PMS ko. nararamdaman ko kasi na mayroon vibration pag tumatakbo ko ng 90 Kph+. Now nasa 47,000Km+ na, wala pang vibration. so ok pa ang pagka balance ng gulong. Hindi pa ako nagpa balance ulit.
    Ang alignment naman ay makikita kung pantay ang pagka-pudpud ng gulong. Kung pantay naman, malamang naka align pa. Ang problem lang sa alignment ay matagal na palang hindi align kasi hindi pantay ang pudpod ng gulong. nakakaiksi ng puwedeng itakbo ng gulong.
    dahil sa hindi tayo independent suspension sa likod. basically walang alignment problem sa likod. Harap lang.
  4. #344
    Thumbs down Re: Avanza Periodic Maintenance Sevice (PMS)
    Mam Jane as per your request, please find my Vanzy 20K, KM PMS and actual charges breakdown na binayaran sa Toyota, San Fdo. Pamp. ng esmi ko... last week lang ito...
    Heto mga ginawa kay Vanzy ko for 20K-KM, PMS
    - nireplaced..engine oil,filter,sparkplugs,air filter
    - inspect drive belts
    - refilled engine coolant
    - check exhaust pipes & battery mountings
    pcv valves at lahat dami nakasulat..lahat yan ininspect..madami pa inispect lahat sa car....upgraded to toyota synthetic blend motor oil...
    20km check up............................ PHP 1,484
    4 liters oil................................... PHP 1,669
    element oil filter............................PHP 403.86
    sparkplugs.................................. PHP 555.76
    gasket........................................PHP 28.56
    misc. .........................................PHP 150
    brake cleaner...............................PHP 255
    distilled water battery top-up..........PHP 28
    total ..........................................PHP 4,575.02
  5. #345
    Join Date
    Aug 2005
    *levanz2007,
    Hindi ba J ang avanza mo? If J, 3 liters lang ang oil.
    What type of oil ang ginamit? ang full synthetic kasi ay about 600 petot per liter. Mineral is les than 300 or 200 per liter (if i remember correctly).
    Price ng oil filter and spark plugs are all casa standard. no magic there.
    Distilled water is 15 petot per liter sa labas.
    sa Shaw, kasama na ang brake cleaning sa PMS. bakit kaya may charge ka for brake cleaner?
    Para saan ang gasket?
  6. #346
    Join Date
    Dec 2007
    Oo nga, gasket? Baka ginamit sa oil filter? Or sa drain plug?
  7. #347
    Join Date
    Dec 2007
  8. #348
    Join Date
    hmmm hindi ko din nakita exactly where that oil gasket is placed pero based sa mga nababasa ko before adviseable na palitan yung gasket every time mag pa change oil particularly pag Fully Synthetic na matagal ang palitan, assuming the next 5k is top up lang ginagawa, kasi nagdedeteriorate din yung gasket overtime. anyway, mura lang naman hehehe!
    try kong hanapin yung mga links i read about gasket may mas technical explanation kaya lang hindi na kinaya iabsorb ng brain cells ko sa dami ng technical words....yung nag register na lang is yung conclusion na "change regularly" hehehe
    Sir Levanze yung sa aking ordinary oil lang po kaya mura lang damage.
    RE. battery fluid refill, naku sa akin mura nga ang batt fluid sa labas pero mahirap i-DIY dahil baka mag over fill ka at umapaw madamage pa yung engine mo....i experience this problem with my stock batt nag spill yung fluid at nacorrode yung metal parts ng engine ko. At dahil di ko naman pinapakialaman yung engine at naka reflect naman na sila nagrerefill, I was able to claim sa warranty yung repainting ng damage parts at replacement of batt.
  9. #349
    Join Date
    May 2008
    Nagpa-quote ako sa TYT SM NORTH ng 20k PMS, anak ng kamote 15k!!!! Nung pinatanggal ko lahat ng add-ons, (sabi ko kung ano lang ang check-up sa 10k ang quote mo, which is P5,400++) ang binigay sa aking quote is 7k++!! Langhiya! Mas mataas daw ang labor fee pag 20k kaysa sa 10k.
  10. #350
    Join Date
    Sep 2005
    yung 20K ko sa Toyota Shaw 4,016.73 lang.. pero hindi ako nag change oil.. nung 25K ako nag change oil.. 3,590.10 lang charge..
    sa Toyota shaw mo dalhin.. hanapin mo si sir Tony..
  11. #351
    Join Date
    Quote Originally Posted by bondz22 View Post
    hmmmm sir kasama ba dyan alignment (camber + wheel)? Ako kasi 5k din orig quote sa akin pero pinatanggal ko muna yung alignment kaya around 2.6k lang ang siningil (please refer to my earlier post).
    Also, aircon cleaning is part of 20k PMS yung sa akin I had it done last January to avail of the discount.
    Isa pa sir mas mahal pag fully synthetic ang ilalagay at kung magpapa engine wash, or meron kang ipapacheck up na unusual with your car.
    Tip sa akin before ng friend ni hubby working sa casa na pag magpapaPMS sabihin lang sa SA na "regular PMS lang at no additives"~ overtime I realized na meron silang list of "recommended" jobs every PMS pero the customer may opt not to have it all done.
    The problem din kasi with other SA pag nagpaquote ka they only tell you the total amount but they don't bother explain or take time to explain sa customer kung ano ang included dun sa quote nila.
  12. #352
    Join Date
    nung 20k PMS ko pinatanggal ko yung alignment....last weekend my uncle drove my vanzie and he told me pumapaling sa left if you drive at a constant speed and let go of the steering wheel....advice ni Tito ipa-check mo na alignment.....ok naman tire pressure when I checked it.......waaaaa talagang 25k isasama ko na yang alignment na iyan!
    paging shadow and harryparrot...yun ba yung sinasabi nyong may kabig? yun pala yon???!!!!
    ipon ipon ipon
  13. #353
    Join Date
    Aug 2005
    Pag may kagib, medyo hindi rin maganda ang upod ng gulong at possibly hindi safe at high speeds.
    pag nag brake ka ng dahan dahan, (slow speed ha. mga less than 20Kph) hindi dapat liliko or kakabig pag binitiwan ang manibela habang nag brake.
  14. #354
    Join Date
    Dec 2007
    ipon ipon ipon
    Yup, prenster. May kabig nga kapag ganyan. Assuming na flat/pantay ang surface ng dinadaanan.
    Mas makakatipid ka siguro kung sa labas mo ipapa-align, NOW NA! The sooner you have it corrected, the less uneven tire wear you'll get.
  15. #355
    yung sa gasgas ng gulong "camber" correction or alignment po yata yan... lalot hindi pantay ang gasgas ng gulong mo , yung iba paloob ang gasgas yung iba naman palabas ang gasgas... may fault na sa camber ang sasakyan nun...
  16. #356
    Join Date
    * prenster and levanz
    thanks ....test ko ulit pag ako lang nakasakay mag isa if papaling pa rin kasi nung test ko nasa tabi ko si GPS baka kaya pumapaling eh kasi mabigat si don primo hehehe
  17. #357
    Join Date
    Oct 2007
    Wag mo na hintayin 25kpms, pa align mo na mapupodpod tires mo, kahit sa labas mura lang yan less than 500 computerized dapat hah. Last alignment ko 150 lang 4 years ago. Wag mo lang sabihin sa casa na sa labas ka nag pa align, la naman marked yan na sa labas ginawa.
  18. #358
    Join Date
    Apr 2009
    naka 8240km as of reading my ODO today, na missed ko ang 1k at 5k PMS waaah. ngayon sakit ulo ko dahil kailangan maipa PMS ko.
    I asked Toyota Alabang to avail my 5k PMS pumayag naman sila and change oil if fully synthetic ang gagamitin aabot ng 3100 petot, this coming saturday ako nag pasked, insist nila Service na better gawin na ang 10k PMS sabi ko pag exact 10k na lang. baka pwede nyo ako matulongan what else ang pwede gawin sa 5k PMS.
  19. #359
    Join Date
    Oct 2007
    Quote Originally Posted by Lady_fox View Post
    Saturday pa??? dapat ngayon o kaya bukas...anyway lagyan mo muna oil treatment kung saturday pa.
  20. #360
    Join Date
    Sep 2005
    hmmm eh kung magpa 10K ka na.. gagawin na nila lahat yung gagawin sa 10K.. plus fully synthetic.. para next PMS mo sa 15K na.. then next change oil sa 20K..
    pag nagpa 5K ka kasi ngayon.. tapos 10K pag exact 10K ka.. pag 15K change oil na naman..
Posting Permissions
  • You may not post replies
  • You may not edit your posts
