Page 15 of 25 FirstFirst ... 5111213141516171819 ... LastLast
Results 141 to 150 of 248
  1. #141
    Join Date
    Jun 2006
    Default Re: Avanza Headlight Upgrade
    tumaas pa ulit , last month kuha ko sa blade sm lipa eh 2290. yun nga lang sa tingin ko sulit naman lalo na sa laging bumibyahe sa gabi.
  2. #142
    Join Date
    Feb 2005
    Quote Originally Posted by bolty View Post
    in demand kasi at maganda ang feedback sa philip extreme kaya biglang naubos daw, then nung lumabas ayun mahal na hanap hanap lang meron pa nyan mura, kung sino maka scout pa share yun shop para lusob avanza!
  3. #143
    Join Date
    Aug 2005
    Sa banaue talaga mas mura. May nag post na less than 1.6K daw ang 1 pair.
  4. #144
    Join Date
    Sep 2005
    siguro alternative brand is osram NB or narva all-weather ba yun?
  5. #145
    Join Date
    Sep 2005
    sabi don sa isang thread.. sa C3 4x4 daw meron na.. 1.5K daw yang X-treme.
  6. #146
    Join Date
    share ko lang dito tinuro sa akin ng Toyota Bacolod technician kung pano mag adjust ng angle ng headlamp ng avanza, pina adjust ko kasi headlamp ko kasi masyadong mababa yung ilaw ng HID ko. Tools needed, one philips screw driver, isang flat na wall, masking tape or pencil or marker. park your avanza facing a flat wall then turn on your headlight, mark the topmost edge of the light with a masking tape or pencil or marker, adjust the headlamp angle to desired position. hope this is helpful.
    heto yung guide slot para sa philips screw driver
    insert the philips screw driver to the guide slot then turn clockwise or counterclockwise
    adjusting the driver sige headlamp angle
  7. #147
    Join Date
    Aug 2005
    Sa stock HL, no need to adjust.
    Pag fully loaded, lalo na pag sa likod, tumataas ang buga ng ilaw as if naka bright ka.
  8. #148
    Join Date
    yep, sa akin tama lang level ng stock HL
  9. #149
    Join Date
    Dec 2008
    Quote Originally Posted by flying_fox View Post
    tsk tsk tsk ganito na pala kamahal ang price ng philips extreme.
    sir flying fox di ba dito kayo sa Japan buy philips, saan store kayo nag-buy dito? kasi 2 yellow hat store na tiningnan ko pareho wala.
    TIA
  10. #150
    Join Date
    sir h83d, dito ko nabili ang phillips extreme, try mo hanap dyan sa Tokyo.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
