Results 141 to 150 of 248
Thread: Avanza Headlight Upgrade
September 22nd, 2009, 05:43 PM #141
- Jun 2006
- 78
Re: Avanza Headlight Upgrade
tumaas pa ulit , last month kuha ko sa blade sm lipa eh 2290. yun nga lang sa tingin ko sulit naman lalo na sa laging bumibyahe sa gabi.
September 23rd, 2009, 07:41 AM #142
September 23rd, 2009, 12:49 PM #143
Sa banaue talaga mas mura. May nag post na less than 1.6K daw ang 1 pair.
September 23rd, 2009, 12:56 PM #144
siguro alternative brand is osram NB or narva all-weather ba yun?
September 25th, 2009, 09:40 AM #145
sabi don sa isang thread.. sa C3 4x4 daw meron na.. 1.5K daw yang X-treme.
September 25th, 2009, 08:51 PM #146
share ko lang dito tinuro sa akin ng Toyota Bacolod technician kung pano mag adjust ng angle ng headlamp ng avanza, pina adjust ko kasi headlamp ko kasi masyadong mababa yung ilaw ng HID ko. Tools needed, one philips screw driver, isang flat na wall, masking tape or pencil or marker. park your avanza facing a flat wall then turn on your headlight, mark the topmost edge of the light with a masking tape or pencil or marker, adjust the headlamp angle to desired position. hope this is helpful.
heto yung guide slot para sa philips screw driver
insert the philips screw driver to the guide slot then turn clockwise or counterclockwise
adjusting the driver sige headlamp angle
September 26th, 2009, 10:52 AM #147
Sa stock HL, no need to adjust.
Pag fully loaded, lalo na pag sa likod, tumataas ang buga ng ilaw as if naka bright ka.
September 26th, 2009, 07:55 PM #148
yep, sa akin tama lang level ng stock HL
September 26th, 2009, 11:23 PM #149
September 27th, 2009, 12:02 PM #150
sir h83d, dito ko nabili ang phillips extreme, try mo hanap dyan sa Tokyo.
For modern cars, the EPS seems to be more ubiquitous as the traditional engine-driven PSF...
A/c
