test
Page 12 of 13 FirstFirst ... 28910111213 LastLast
Results 221 to 240 of 251
Thread: Avanza Engine Problem
  1. #221
    Join Date
    Sep 2012
    Default
    Quote Originally Posted by solbesinga View Post
    Gudpm to all, just bought a second hand 2007 avanza g at 49tkms reading,manual transmission, ive checked if its flooded, and its not. Question lang po mga sir, kasi when i test drove it ok naman, pero nung pauwi na kami after thepurchase, napansin ko pag shift ako third gear, sometimes kumakadyot sya upon 3 to 4rpm, pero minsan smooth naman.i dont know if the correct term is JERKING? Anyway pinascanner ko sya sa , wala naman mga faults sa sensor everything was fine daw, hindi lang daw ako sanay, so i drove my tita's avanza in the same manner pero di sya kumakadyot, ive tried all themechanics here in our place pero wala makapinpoint, hindi kasi consistent ang problem, at hindi palyado ang makina, minsan maayos manakbo, kayaginagawa ko pag kumakadyot ng malakas tinatapakan ko nalang ng malakas ung accelerateor... So dissapointed, as of now wala pa ako budget for casa.... Ask ko lang if may naka experience na nito sa inyo? At kung ano kaya possiblecause?
    Sir release bearing ng cluch sa loob ng transmission sira nyan sure ako dyan
    Sent from my iPad using Tapatalk HD
  2. #222
    Join Date
    Jun 2007
    Default Re: Avanza Engine Problem
    baka sa gas na kinarga mo?
    mataas pa po yung gas nung nakuha ko. almost full tank
  3. #223
    Join Date
    Jun 2007
    kaso para syang nabibilaukan at kumakadyot kahit di ako nakatapak sa clutch>???????
  4. #224
    Join Date
    Sep 2012
    Default
    Ok sir na try nyo na po ba patingnan mga spark plug and ung dinadaluyan nya kuryente kase sa exprncd ko po ung mga sinalumang kotse like boxtype lancer pag may leak na ung hi tension wire nabubulunan ako pag nag tilsera ako lalu na pag na overtake nabibitin eka nga
  5. #225
    Join Date
    Sep 2012
    Default
    Sir malamang po talaga release bearing nga po sira kase naka release na kayo sa cluch e ayaw pa po bumitaw nung bearing kaya parang nabibilaukan po at pakadyot kadyot haha natatawa ako sa term ;)
  6. #226
    Join Date
    Jun 2007
    Quote Originally Posted by Batangenyo View Post
    fuel filter ang chine check ngayon ng mekaniko dito sa amin, thanks for the info though, salamat sa mabilis na mga reply. ill update nalang po kung naayos, or naglaho lang ang ibabayad ko.. THANKS TALAGA
  7. #227
    Join Date
    Sep 2012
    Default Avanza Engine Problem
    Sir any update sa avanza? (Y)
  8. #228
    Join Date
    May 2012
    Hello mga Sir! newbie lang po. question lang sa AT 2012 G Variant, 1) normal lang po ba na mag jerk kapag naka-Park mode after kung i-release yung break?
    2) tsaka po pag nag change ako from Reverse to Drive (or vice versa) may tumutunog (yung tunog nya parang tunog sa manual kapag hindi natapakan nang maayos yung clutch kapag nag change gear) ? bale 1 month old palang po unit ko. Thanks.
  9. #229
    Join Date
    Feb 2012
    Quote Originally Posted by Dimebox777 View Post
    Check your ATF if it's on optimal level. Kung kulang yan, ganyan ang nangyayari.
  10. #230
    Join Date
    Feb 2012
    A big possibility nga yun fuel filter. I think it's an electronic fuel filter located inside the fuel tank.
  11. #231
    Join Date
    May 2012
    Quote Originally Posted by batch View Post
    thanks sa info sir, ganun ba talaga sir kahit bago pa lang? napansin ko kasi yun 1 week after na deliver. anyway try ko hanapin yung ATF thanks
  12. #232
    Join Date
    Aug 2005
    nagpalit na ako ng in tank filter. parang papel lang lang ang filter. BTW, mga 100,000 km plus ng nagpalit.
    Sorry nakalimutan na kung magkano.
    Kailangan ibaba ang fuel tank.
  13. #233
    Join Date
    Dec 2012
    Good day guys....im a newbie here and newbie din sa driving...avanza kasi first car ko and just recently got my non-pro license.
    may problem kasi is about the IDLE SPEED CONTROL ACTUATOR...sinabotahe kasi nung part-time driver namin yung sasakyan.
    tinanggal nya yung connector ng ISCA. First question...pwede ba gamitin yung car if wala yung ISCA? Second...where to buy the connector and how to crimp
    Third..Baka meron kayong copy ng connection or wiring diagram nun......Thanks in advance.
  14. #234
    Join Date
    Sep 2010
    try mo dito sir:
    ToyoDIY.com
    select mo lang yung model ng avanza mo.
    try mo din post sa ACP:
    Toyota Avanza Electrical Diagram
    (me mga topics na required to register. meron din naman na browseable
    as guest).
  15. #235
    Join Date
    Jun 2009
    Hello , napadaan lang po ako, baka meron ako bago matutunan dito at baka meron ako maishare. Last post ko pa ata year 2010. Now I have 3 avanza unit, all converted sa taxi, I have experience so many problems, mechanical and electrical. So far lahat naman nasosolved namin. odo reading ng 3 units ko 300K, 100K at 60K km.
  16. #236
    Join Date
    Oct 2008
    napansin ko lang yong throttle ko madumi dons sa me butterfly. meron na ba naka pag try mag linis nito? ano po ginamit nyo solution?
    thanks
    thanks
  17. #237
    Join Date
    Throttle body cleaner from CRC or Wurth
  18. #238
    Join Date
    Oct 2008
    san po nakaka bili nyan? parang wala ako nakita ganyan sa Ace/Handyman
  19. #239
    Join Date
    Oct 2015
    Greetings from Avanza Club Pilipinas Inc.
    The Avanza Club Pilipinas Inc. is a group of Toyota Avanza lovers and owners from the Philippines established in Tsikot since 2006 with SEC Registration Number: CN201517636. Our clubs mission is to help our community by sponsor one charitable institution. It also promotes camaraderie, harmony and education to promote safety in driving, automobile maintenance and improve vehicle operation.
    _https://www.facebook.com/groups/avanzaclub.ph/
    please remove the underscore to direct to to site.
  20. #240
    Join Date
    Sep 2016
    Quote Originally Posted by antoine_hans View Post
    ayos! sir idle problem ex taxi avanza j 07 model.ang haba na po para mag back read.Thanks in advance sir.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
