Here's how to replace our beloved ride's headlights...
You'll need the following:
- Replacement H4 bulbs
- Two fingers, preferably thumb and index finger
- Good lighting (daylight or flashlight
- Courage
- A little strength
Let's begin the walkthrough for one (1) headlight...
1. Pop the hood.
2. Locate the back portion of the headlight. Identify the modular plug:
3. Remove the modular plug (just pull it out gently, moving it a little bit from side to side):
4. Locate the protruding rubber so you can use it to pull off the rubber cap/cover (my index finger is touching it here):
To be continued...
