Results 31 to 40 of 294
May 21st, 2008, 01:41 PM #31
Re: Avanza DIY (Insulating Firewall & Ceiling + bluelight)
OT post,
Sa original Avanza thread na lang po.
http://tsikot.yehey.com/forums/showt...25872&page=490
Or create a new Thread for your question. If new thread, please include the work Avanza in the title.Last edited by meledson; May 21st, 2008 at 01:44 PM.
May 21st, 2008, 03:34 PM #32
May 21st, 2008, 04:08 PM #33
*pres
sorry po. di po kasi ako magawa ng new tread.. eto lumalabas.
ngarcia, you do not have permission to access this page. This could be due to one of several reasons:
- Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
- If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
May 21st, 2008, 04:43 PM #34
May 21st, 2008, 05:43 PM #35
Sana tinext mo nalang ako bro. hinde kita nakita kase. Next time nalang.
Ok lang yan ma'am pwede ko i demonstrate. First customer may 50% discount... .
Anyway this morning just done covering the backpart with insulation.
Pictures will be posted asap.
May 21st, 2008, 06:10 PM #36
Just bought a 2meters of 10cm double sided film type insulation this morning.
Now here is the rear hood project as I mention earlier.
PART 1
Here is the original look of our avanza J-type ceiling.
I start by removing this rubber.
This is the clip woohoo and I was talking about.
Taking the clips out. (hope i can return it to original look)
Continue to PART2
May 21st, 2008, 06:26 PM #37
PART 2
After removing the clips here what it looks like.
Now we are going to remove this plastic clip. (easy job)
Next is removing this clip located by the windows (left n right)
This is what it looks so far.. (Man.! can't believe i'm doing this to vanzy)
PART 3
coming very sooonn....Last edited by Marfin; May 21st, 2008 at 06:35 PM.
May 21st, 2008, 09:00 PM #38
May 21st, 2008, 09:26 PM #39
Walapa naman budget sir para jan. Ok lang saakin ung tulad ni sir meledson at Jaspi na JBL.
PART 3
This is the support or should we call hook that brace the ceiling. (removing it by following the arrow movement)
Next we need to remove the center dome light.
Next is the rear door rubber or the middle door to be removed.
And then take all the pull handle off.
Continue to PART4.
May 21st, 2008, 09:39 PM #40
PART 4
Tadaa..!! this is the inside looks like..
Notice the yellow portions pointed by red arrows, these are the area that aren't cover in our ceiling. And the material they used I think serving as sound deadening purpose only. Although it rejects heat but not as good as the Double sided Insulating material that I 'm going to use.
Here trying to fit the material. (red measurement is for the ceiling width and yellow is the material width) All we need to do is cut like 91cm to make it perfectly fit to our ceiling.
Nice.. there are some gaps that can hold our insulation.(less job..)
To Continue PART5
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
