Results 11 to 20 of 294
May 19th, 2008, 08:57 AM #11
May 19th, 2008, 08:58 AM #12
May 19th, 2008, 10:12 AM #13
Re: DIY (Insulating Firewall & Ceiling + bluelight)
*marfin: abangan ko susunod na kabanata (rear part), ganda ng istorya parang teleserye.
May 19th, 2008, 09:56 PM #14
May 19th, 2008, 11:02 PM #15
May 19th, 2008, 11:05 PM #16Tsikot Member Rank 4
- Jun 2006
- 2,605
Sir Marfin,
Can you pls confirm kung may sound deadening properties yung insulation na ginamit mo
May 19th, 2008, 11:22 PM #17
Eto naman yung insulation sa firewall ng avanza natin:
Sorry walang mga step by step dahil experiment ko lang muna kc akalako mahihirapan ako yun pala ang dali lang pala.
Although it looks one whole pero hinati ko rin sya tapos naglagay nalang ako ng 3M double adhesive sa mga corners para dikit na dikit.
Note: meron narin pala abang na mga pins na i belive para sa firewall talaga yan.
This firewall insulation available na sa Gtype AFAIK.
First i doubted na baka hindi makayanan ang insulator ng init ng engine pero na tested na nung nag ACP family outing to bulacan, na kayang kaya ng insulation material pala.
May 19th, 2008, 11:29 PM #18
May 19th, 2008, 11:46 PM #19
Finally eto ung bluelight na sinasabi ko.
Nakuha ko lang idea na dagdagan ng blue light gawa ng built-in na bluelight din yung sa roofconsole. Tinap ko lang yung wire sa may doorswitch(serving as ground) and positive(kinuha ko lang any wire na kulay green w/ red stripe and i believe this wire is connected to interior light fuse.) Nalaman ko lang yun after na short ko sya sa body tuloy nawala lahat ng interior light and i found out later na kailangan ko palitan ang fuse (10A) buti nalang may extra tyo sa fusebox.
Materials:
Bluelight from ACE 100pesos
Driver side
Passenger side
Close up. sayang nga dapat gabi ko pala i take ung picture para malakas ang effect ng blue light.Last edited by Marfin; May 19th, 2008 at 11:53 PM.
May 20th, 2008, 08:20 AM #20
ayus yang blue light na yan.. baka pwede din lagyan yung mga pinto.. para pag ni open yung doors eh may ilaw.. lalo na sa likod..
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
