test
Page 6 of 7 FirstFirst ... 234567 LastLast
Results 101 to 120 of 138
Thread: Avanza Check Engine Light
  1. #101
    Join Date
    Sep 2005
    Default Re: Avanza Check Engine Light
    ^^^ kahit gusto natin makita na ginagawa ang Avanza natin, bawal kadalasan ang customer the servce area.
    Parang sa Toyota Makati lang puwede. Sa mga nabasa ko so far.
    sa Toyota OTIS pwede rin tingnan...nasa labas kasi yung Service Bay Area for PMS.
  2. #102
    Join Date
    Jun 2006
    Quote Originally Posted by Marfin View Post
    I agree with You sir., grabe naman for this reason i ca-charge pa nila ng 1k just to fix this?, I have an experience before w/ mitsubishi pickup na nakagat ng pusa yung wiring and i cant started the car, ang ginawa ng casa pinuntahan sa bahay w/ free charge pa...
    Is this the one that we are talking about? the brown wire looks like for the grounding. Tama ba ako sir jun?
    bro Marfin
    Malamang un kasi negative ground ang mga oto kaya nag trigger ng check engiine light. Di ko lang alam kung it would be the same if the other wire was the one removed. Also un shrink sleeve though maganda at me protection ka normally di naman kailangan kasi weatherpak ang mga sockets natin di basta ma disconnect or loosen under normal driving conditions, except kung mahila ang wire mismo. Sa mga hot wires preferrably vented din sya to prevent the insulation from melting in extreme temperatures kaya di nilalagyan ng shrink sleeve, protective sleeve lang pero me spaces para air gap.
    Ayos
    Jun
  3. #103
    Join Date
    Jun 2006
    Sowi double post
  4. #104
    Join Date
    Quote Originally Posted by Eypeeyu View Post
    nkup!
    jan ko din dinadala ang Avanza ko...
    babae din ang SA ko...paktay na!
    Ma'm Jane, sino yung luko-lukong SA sa TYT Balintawak? Baka siya pa makuha naming SA, mahirap na. Pero sapalaran lang talaga ang mga SA. Malas lang kung napunta ka talaga sa manggagantso.
  5. #105
    Join Date
    Quote Originally Posted by cholui View Post
    siguro iwasan nyo na lang basta babae na SA dun sa service ng toyota balintawak. tama ka tsambahan o sapalaran talaga magpa-service ngayon, bihira na yung matinong kausap at mapagkakatiwalaan.......kaya dapat nakikita mo yung oto mo habang ginagawa, baka mamaya sila na itong nakasira ng pyesa eh at since di mo nga nakikita oto mo sasabihin sa iyo mam/sir kailangan po itong palitan at di kasama sa warranty....patay na...bayad ka na ng walang kalaban laban.
  6. #106
    Join Date
    Sep 2005
    nung saturday ko lang nasilip yung engine bay ko after maayos yung check engine light ko.. eto kinunan ko pics.. kaya lang camfone lagn dala ko eh..
  7. #107
    Join Date
    Apr 2008
    sa tyt balintawak pa naman galing unit ko, better dalhin ko na lang sa tyt shaw para safe ako sa 1st 1000km
  8. #108
    Join Date
    Quote Originally Posted by mick25 View Post
    pag first 1k PMS libre labor but check with Shaw if they will honor yun even if you got your car at BK...pag may problem dun ka sa warranty officer makipag-usap wag sa SA.
    try mo din sa TYT SM North sister company lang naman yan pero pag PMS pwede mong tabihan car mo....that's what I do....mega smile lang ako sa mga technician at di ko na iniistorbo ng katatanong baka mabwisit! Maayos naman service sa SM North.
    Sa Balintawak ok yung nag-assist sa akin na isang male SA kaya lang natapat ako dun sa babae na P*&%$* bwisit...binabalik nila extra oil and even the used spark plugs...sa ibang casa hihingiin mo pa.
  9. #109
    Join Date
    Apr 2006
    FYi
    nag Flash ang Check engine light na din si Vanza ko while driving yesterday while driving, so now Im here at Toyota C5-valle verde since 7am.... and guess what.... Yung Daga Nyo si IkaBod!.. baka sya rin ang nag ngatngat ng wires ko!.. tsktsktsk...(ang sabi na S.A. baka daw me mga daga daw na nag ngatngat na wires sa electrical ko.. what the !*#%) .. tsktsktsk.... ni rectify pa daw nila ngayon ang problem... i already called some backup pag sablay eto lipat na ako sa Toyota Cubao or Makati, me mga padrino sa tabi tabi doon
  10. #110
    Join Date
    Apr 2006
    Update on my check engine lights on
    They found the problem "Loose wire on intake air temp
    Circuit sensor connector (DTC-P0110)" ang problem.. question nalang eh babayaran ko ba or claim ko sa warranty eto ?
  11. #111
    Join Date
    Quote Originally Posted by t3kk3n View Post
    balitaan nyo na lang kami sir kung pinabayaran sa inyo and how much po damage
  12. #112
    Join Date
    Apr 2006
    Binayaran ko muna yung PMS checkup, (P2,2xxx) pero yung sa check light, di pa sabi ko ipullout ko muna yun car.. eh maghapon na nila ginagawa eh, gusto nila gawin (repair lang) ang tanong eh covered ba ng warranty di naman sinasagot... kaya sa ibang casa ko na dalhin, i have the recommendation already so paguusapan nalang eh covered b ng warranty or not, kung di na covered, eh iorder ko na parts ahead, kasi the way they work on in, eh parang ayaw palitan gusto i-repair lang... right now me electrical tape para di magalaw yun wiring, yan ang ipapakita ko sa ibang casa na me padrino ako kakilala hehehe.. and Also FYI .. dito sa Toyota ortigas-C5 nga pala eh di nila accept any BPI Cards. visa/mastercard pwede except for BPI....
    ;) i bring ko nextwk sa toyota cubao or makati ang vanza ko para tapos na issue
  13. #113
    Join Date
    Aug 2005
    Sabi ko na nga ba e.
    Any way, iyong akin ay nirepair lang by soldering the wire to the sensor. That was several months ago. Hindi na bumalik ang problem.
  14. #114
    Join Date
    bookmark for reference....salamat sa info sir
  15. #115
    Join Date
    yung sa case ko they just need to "re-clamp" yung naputol na wire dun lang kasi sa pinagclampan ang naputol...they offered me to replace a portion of the wire pero idudugtong lang dun sa old wire....
    i may not be very good pagdating sa electiricals pero the way I see it mas ok kung magbabalat na lang sila ng less than half an inch para dun i-clamp yung clip....kesa mag-hihinang pa ng wire....mga 1.2k plus din yung pagkakabit ng wire tapos dugtong lang tsk tsk tsk....tutukan mo kasi sir kung ayaw pumayag na tumingin ka bring it to another casa
    back read na lang to see pics po
    HTH
  16. #116
    Join Date
    Sep 2005
    hmmm may bayad?? san ka ba nagpaayos nyan Mam Jane? sa Toyota Shaw Blvd.. libre lang yan.
  17. #117
    Join Date
    walang bayad di ba kasi nilipat ko dun sa SM North pero dun sa BK sinisingil ako ng 1.2kplus pero di ako pumayag....naipasok ko sa warranty....
  18. #118
    Join Date
    Sep 2005
    ahhh ok.. hehehe limot ko na kasi.. napakatagal na kasi non lolz
  19. #119
    Join Date
    Apr 2006
    update on check engine light
    naka electrical tape pa din, tumawag na ako for the parts to be replaced kung kailangan. I called up Toyota Shaw (very defensive sila, sinasabi ko palang ang check engine light ang sagot agad eh 2-3 days) di pa ako tapos magsalita ng findings sumasagot na agad (sinabihan ko yung SA, patapusin mo muna ako mag salita bago ka sumagot, puro kayo defense eh di nyo pa alam ang buong kwento.. .. ayun tumahimik at nakinig naman) anyways.. ang advise nya eh. kausapin ko na yung Head ng Service (Nelson Taruc) for warranty concerns both shaw and ortigas sya ang Head sa service. btw.. vios cars also experience this problem... kc akala nya eh vios car ko.. sabi ko avanza... ;) so di lang pala tayo ang me problem sa ganito.. anyways.. ill be bring the vanza on wed sa casa to have the problem solved
    ** re: wiring ningatngat ng daga **
    yun wire ng sensor parang me plastic/rubber na naka wrap bago pa yun wire itself... walang ngatngat ang plastic/rubber wrap pero ang wire sa loob meron?.. so tinanggal ba or binaba ng daga yun wrapping bago ngatngatin???
    hmm mechanic siguro yun daga? hehehehe
  20. #120
    Join Date
    Apr 2006
    FYi
    wala daw parts replacement for Avanza, etong wiring na eto... hahanapan lang daw ng wires na sukat at iconnect doon sa terminal... ... Ganito ba talaga? .. Toyota shaw-ortigas eto (C5- near Sm Tiendesitas) pwede bang i-DiY na lang eto?????
Posting Permissions
  • You may not post replies
  • You may not edit your posts
