^ just thinking out loud here, paano kung for dry hair yun shampoo gamitin?![]()
can anynone compare microtex's pro choice vs car shampoo and/ or car shampoo w wax? i only used the shampoo w wax...and is intrigued with the pro choice option![]()
Currently using BigBerts car shampoo. sulit. been using it for months, hindi pa ubos, carwash every weekend.
naubos un ginagamit kong car shampoo nun isang araw
kaya nag joy ako.. ayos pala yun mabula
kaya lang pagdating ng hapon inihian nun bata yun bumper ko.. setbuuuu!!!!
may nabili ako sa ace dati Simoniz car shampoo Php50 petot lang per 500ml.![]()
"Whatever floats your boat."
If using hair shampoo works for you and your car, then keep using it. It will only affect your car and one else's.
Detailing enthusiasts that I personally know, who avoids swirls and has glossy paint, use proper car shampoo and chemicals. They put effort in polishing and waxing their paint and would avoid undoing the hard work that they've done and will certainly not use hair shampoo on their vehicle.
Kung sa pwepwede, pwedeng gamitin and hair shampoo...ang tanong, is it worth the savings?
BTT: Matagal nako naghahanap nyang microtex sa sachet...Mas tipid ako pag yan gamit ko...sa isang pack of two, kaya ko gamitin in 4 carwash...so 2.50 lang per wash...Mas mura sa hair shampoo..![]()
yung iba kasi sabi mawawala daw yung protective coatings ng paint...well the post explained it all.
anyways, ginamit ko lang yung hair shampoo kapag emergency o naubos na yung car shampoo talaga, malinis lang ba. worth the savings? nope. nagalit pa nga sa akin si misis![]()
Ah okay sir sayang din ang 20% off. Walandyo itong store manager hindi man lang ako tinext nung nagka 20% off.
Posted via Tsikot Mobile App
Ano difference ng microtex shampoo at ng microtex wash and wax. And which is better
Sent from my SM-N920S using Tsikot Forums mobile app
basically same lang, may wax lang yung isa, sort of all in one kaya parang makintab na rin pagkatapos ng washing. better to apply a good wax pa rin para maganda protection
if you plan to do full paint correction, you need to strip the paint with existing wax prior to polishing so advisable to use yung shampoo lang. kapag kasi may wax pa yung paint, hindi ma-maximize effect nung polishing compound...
megs ult w&w and autoglym.. ph balanced for car pubic areas. 🤣
