Results 1 to 6 of 6
    anong gagamitin ko na sandpaper para mapantay ko yung touch uppaint?
    after that polish dba?
    also what is the best way to apply touch up paint?
    Are you proficient with sanding?
    Understand that after sanding, you'll have to compound and polish after as well...
    3 or so swipes with a sandpaper (even if you use 2000 grit) can pretty much scrape all the clear off your surrounding area... don't say i didn't warn you... ;)
    Anyway, if you really wanna try, read these...
    http://www.web-cars.com/detail/touchup.html
    http://www.paintscratch.com/automotive-paint-tips.htm
    i plan to have it repainted kasi. so i though this would be a good oportunity.
    san makakanili ng nick sander?
    mga how much kaya yun?
    sa states mura lang, not sure kung meron dito, you might wanna ask paint shops for fiberglass tipped pens.
    fiber glass tip pens? what doe sit look like?
    also what rubbing compound should i use? how much do they cost?
what sand paper to use for touch up?
