In the process of painting, common practice na yung wet sanding ng putty after it dries. Is it true that this could do harm as the moisture would seep into the putty and eventually be a cause of corrosion?
wet sanding process, kailangan yun para mas madaling liha-in yung putty di ba? kasi in my experience, sanding a painted surface with dry sanding paper seems so tedious unlike when the sanding paper's wet.
i'm having second thoughts. baka ang ibig sabihin ng honda is wet sanding done by hand. otherwise, their process seem to use something like a sanding device. may hawakan e.
