Results 1 to 20 of 29
    Aug 2006
    Hi! I'm planning to have my car repainted, so now I'm doing my research. May I ask for your opinions on the different paints such as Anzahl, Dupont and K-92? What are the pros and cons of each type of paint (with price being a consideration as well)? and if I may ask, if you were asked to rank the 3, how would your rankings go?
    your comments and opinions would be of a great help and sincerely appreciated! thanks!
    Question ko din to mga sirs. Is anzhal still the toughest paint pa din up to now? TIA.
    Aug 2006
    Anzahl>Dupont. I don't know about k92.What kind of dupont paint you want to spray?
    Feb 2006
    In Sikkens I trust.
    hindi ba pare-pareho lang ang mga paint basta 2k-polyurethane? sa prep naman nagkakatalo usually eh.
    Aug 2006
    hi ronald...im just thinking dupont in general right now, don't know the specifics of the different brands just yet. why do you say that anzahl>dupont? im just trying to understand the difference between the different choices =) thanks!
    Aug 2006
    Quote Originally Posted by ssaloon View Post
    Yes, prep is the key but you also need to consider your paint,guns.May mga paint the low quality in the long run nag fade na yung clear coat and some paint are hard to spray and it wont even lay flat.Nagkakaktalo rin yan sa clear coat ng brand.You can't mix and match ang paint brands due to chemical reactions so kung ano yung brand ng base mo ayun din dapat and clear coat mo.For me,Kung sino ang may pinaka matigas na clear coat wins.Ano bang variants ng dupont sa pinas?marami kasing class ang dupont may pang cheap ass to hi end.
    Whatever you choose stick with polyurathene.Never mind the environment.
    Aug 2006
    Quote Originally Posted by flagg View Post
    In Sikkens I trust.
    have you heard of the Wet Look promo using Sikkens? ok kaya yun? 25k for a washover using straight colors lang. seems a bit expensive pa rin for me considering washover lang though..
    Aug 2006
    thanks for the inputs ssaloon and iluvdetailing...hanapin ko din yung thread na yun ni theveed if i haven't read it already =)
    it seems though that anzahl is a cheaper alternative...is that right? and if so, bat ganun? i read in a post from kbh na in his opinion, di 2k paint ang anzahl. just wanted to know more about that.
Need opinions on Anzhal, Dupont & K-92
