Can aluminum sheets be painted ? Is there a special process or treatment that should be done first before you can paint an aluminum sheet ?
Yes it can be painted. Apply first etching compound na available sa hardware then you can paint it.
pwede po, ituturo ko po step by step. 1. degrease the sheet metal 2 sand with 400 grit 3 degease again 4 apply 2 thin coats of anzal wash primer [ kailanngan manipis at nasisinagan pa yung aluminum ] 5 after ten minutes without sanding the wash primer apply 2 to 3 medium coats of anzal anti corrosion primer then proceed with the normal painting, good luck po
