Results 1 to 3 of 3
- Sep 2012
- 15
September 9th, 2012 05:09 PM #1Can aluminum sheets be painted ? Is there a special process or treatment that should be done first before you can paint an aluminum sheet ?
September 9th, 2012 07:22 PM #2
Yes it can be painted. Apply first etching compound na available sa hardware then you can paint it.
- Jan 2010
- 126
September 10th, 2012 10:18 AM #3pwede po, ituturo ko po step by step. 1. degrease the sheet metal 2 sand with 400 grit 3 degease again 4 apply 2 thin coats of anzal wash primer [ kailanngan manipis at nasisinagan pa yung aluminum ] 5 after ten minutes without sanding the wash primer apply 2 to 3 medium coats of anzal anti corrosion primer then proceed with the normal painting, good luck po
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
