Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Sep 2006
    i have a problem, meron kase free na clear plate cover from honda, the problem is everytime na maglilinis ako ng tsikot e yung tubig ay pumapasok inbetween sa cover and the plate number, pag pinatuyo ko ng ganun e ang panget, ang ginagawa ko tuloy binabaklas ko pa lahat (cover and plate) para lang mapatuyo ko yung loob, anu kya maganda ilagay sa edge nun para di na pasukan ng tubig? yung di halata at yung hindi jologs, ok sana kung clear din, baka kse ma loose thred yung mga screws kakaalis ko at nakakapagod na din, or should i get a different plate cover?
    seal it with clear silicone sealant. available sa nearest diy shop in tubes. the best will be the dow corning glass sealant, same type used for sealing aquarium glass.
    Jul 2006
    Remove the plate cover. ;)
    Remove it. Even the clear cover produces glare at certain angle which makes it hard to read the numbers.
    Quote Originally Posted by mbeige View Post
    yup. agree, para di na rin mainit sa mata ng LTO. masisita't masisita ka pa dyan maski hindi tinted yan....
    I have the "Deflector". Hindi naman napapasukan ng tubig.
    Sep 2006
    ganun ba, bawal din ba kahit clear as in clear yung cover?
    ayoko tangalin kase mabubura yung plate kakalinis at punas, dame nako nakikitang ganung plate at ang panget din
    Yung plate ng L300 na walang plate cover sa ospital nabubura na. Hindi lang yung graphics ni Rizal, pati yung alphanumerics. Basura talaga ang quality. Kabago bago pa lang nung sasakyan.
    Kaya nilagyan ko na din ng clear Deflector yung Starex and Picanto bago pa maagnas yung Rizal plates nila.
    Jul 2006
    Remove the plate cover then spray your plate with clearcoat paint. Repeat spraying as desired - that's what I did and it looks great.
    Sep 2006
    using a clear plastic cover is alright, unless it is tinted. the law does not prohibit placing the plate inside a plastic cover. what is being punished by law is (1) not keeping your plate clean, (2) failing to ensure that it is readily visible or (3) not attaching your plate in front and at the back of your car. tinted plastic cover is unlawful because it makes the plate not readily visible and thus defeat the purpose of the plate. fyi lang po.
    Quote Originally Posted by bat_zignal View Post
    Also though about this. But it does not solve the problem of the plates getting folded up.
    Yung Expedition na nakagarahe sa MMH, nawalan na ng isang digit. When it was sold, the first letter was just about ready to fall off na din. Probably as a result of students (may school kasi) getting their clothes/bags caught on the license plate.
    Sep 2006
    cge try ko lahat ng sinabi nyo, tnx guys
    oo nga badtrip pag nabura na, parang kahit gaano kakintab tsikot mo pagdating naman sa plate, wala na basura na
    Jul 2006
    Probably the best solution here.
    Baka hindi lang totally lapat yung silver na border nya over the glass cover. So far sakin naman hindi pinapasok ng tubig.
    Quote Originally Posted by starbutt View Post
    yup, we are aware of this. what i was implying on my previous post is that pwedeng palabasin ng LTO na may takip pa rin yung license plate mo, maski hindi tinted, pwede nilang palabasin na hindi pa rin visible...so hassle yan sa driver...
    much better kung wala ng takip, iwas hassle.
    Sakin naka deflector, Ok naman sya. Palagay ko Ok lang ito dahil sa very clean and clear naman yung cover.
    Real glass ba yung deflector na plate cover?.....kasi what I'm looking for is "real" glass plate covers with frame...I read in another thread sa Aguila Glass daw meron available...meron ba ganyang store dito bandang Laguna area?
    Acrylic po ang lens ng Deflector. Sa Aguila, glass pero walang boarder. Talagang papasok ang elements between the plate and the cover.
    Currently, Aguila clear ang gamit ko sa likod. Sa harap naman ay Euro style black fiberglass plate frame (walang lens).
    Jun 2006
    Magkano po bumili ng plates sa LTO? AFAIK, pwede yun right? pag sira na yung plaka, pwede ka bumili ng bago? madali lang po ba ito?
    thanks
    Sep 2004
    From lto.gov.ph:
    Request for duplicate plates
    Documents Required For Private Motor Vehicles
    1. Original Certificate of Registration (CR) and latest original Official Receipt (OR) of payment
    2. Actual inspection of MV with duly accomplished MVIR
    3. Clearance from LETAS 4. Clearance from LETAS
    4. Taxpayer's Identification Number (TIN)
    Documents Required For For-Hire Motor Vehicles
    2. Affidavit of Loss
    3. Actual inspection of MV with duly accomplished MVIR
    5. Taxpayer's Identification Number (TIN)
    Procedure:
    1. Proceed to the transaction counters and submit all the required documents to the Evaluator for evaluation and computation of fees.
    2. Actual inspection of motor vehicles with duly accomplished MVIR.
    3. Proceed to the Cashier when your name is called for the necessary fees and obtain an Official Receipt (OR).
    4. Proceed to the Releasing Counter when your name is called to obtain the Certificate of Registration (CR), plates, stickers, and other requested documents.
Plate Number Cover
