Results 1 to 14 of 14
    Jun 2017
    Mga ka-tsikoteers tanong ko lang po kung pano idetermine kung paint transfer yung markss isang sasakyan. May tar**tado kasi nakadali ng side mirror kung while on my way to school sumingit bigla sa gilid ko tas nadali niya yung side mirror tas kumaskas dun sa mini truck di man lang tumigil tas tinakbuhan lang ako.
    Jan 2016
    Quote Originally Posted by khun22 View Post
    Side mirror mo ba natamaan? body color ba side mirror mo? anong kulay ang naiwan? dati kasi yung sa akin naiwan is parang black na mark, from the side mirror ng taxi. pina buff ko lang natanggal naman. pa check mo lang sa mga detailers, alam nila kung matanggal or not.
    Jun 2017
    Quote Originally Posted by Eevie View Post
    Yes side mirror po yung tinamaan, white po b yung color ng side mirror ko po, somewhat yellowish yung naiwan and yellow/yellow orange yung minintruck na dumali, i was planning on getting a full car detail in the near future should i just go nalang po ba sa professional detailer kasi po I was planning to follow Chris' fix tutorial on how to remove paint transfer kung sakali pain transfer lang. Nalimutan ko picturan yung tama will try to picture it later nasa class na kasi ako ngayon bakanmay maligaw na knowledgeable detailer baka sakali madetermine nila.
    Feb 2017
    Bili ka ng rubbing compound then ikaw na lang mag buff. Kahit wala ka rotary polisher pwede naman.
    Jun 2017
    Quote Originally Posted by zero3 View Post
    May marerecommend ka po ba na rubbing compound?
    Jan 2008
    Meron 3M rubbing compound sold in sachets.. just enough for your need. Lagay ka lang ng small amount sa basahan tapos rub gently sa paint transfer.. diinan mo ng konti yung pag rub kung ayaw matanggal.. pero wag sobra kasi baka yung paint mo naman matanggal
    3M meron nabibilang sachet lang. Parang non gritty type pa tub rubbing compound nila.
    Feb 2017
    Yung 3m sachet or kung gusto mo mothers o kaya meguiars pero nasa bote yan at medyo mahal 700 to 1k. Pwede rin pang-tanggal ng scratches yan.
    I use polishing compound first. It's less harsh than rubbing compound.
    Jun 2017
    Mas malalim mag cut ang rubbing compound. Parang sand paper mas coarse yun rubbing compound.
    Ah i see so parang mas mataas na grit yung rubbing compound than yung swirl and scratch remover?
    meron din po ba na naka sachet lang yung polishing compound ng 3m?
    Oct 2017
    Would toothpaste be any good?
    Jun 2017
    Quote Originally Posted by Niner_seven View Post
    Ang alam ko pwede kasi may abrasive compound din ang toothpaste ata, pero diko lang sure kung gano ka abrasive.
    BTW natanggal ko na buti paint transfer lang. I followed Chris Fix's video on removing paint transfer.
How to determine if the mark is paint transfer.
