Results 1 to 6 of 6
August 22nd, 2006 09:15 AM #1
hi! how can i remove the rainaway coat on my windshield? nag-sskip pa rin wiper ko eh. kahit bagong linis and kaka-re-apply lang nung rainaway.
thanks
August 22nd, 2006 09:38 AM #2
sir, di you try cleaning your wiper blades instead? minsan kasi dun ang nagiging problema.
August 22nd, 2006 09:50 AM #4
that usually happens. try cleaning the wipers.
or, you can get a vinegar solution and clean your windshield.
claying, yes, is another solution... along with having it polished.
August 22nd, 2006 09:58 AM #5
will the claying remove the rainaway?
the wiper blades are clean... i'll try yhe vinegar solution. thanks!
August 26th, 2006 01:07 PM #6
Same problem encountered too with rainaway. Any suggestions of what to use on windshields like rainaway without the effect of the wiper blades jumping? Badly needed cause its rainy season and i travel a lot. TIA
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
