Page 238 of 392 FirstFirst ... 138188228234235236237238239240241242248288338 ... LastLast
Results 4,741 to 4,760 of 7833
    Aug 2014
    #4741
    Mga bro need your help. My roof on my nissan sentra 07 model has some faded paint. Parang siyang white clouds although its not that severe mejo oc lng ako sa oto. Kaya pa ba to nang wax or detailing?
    Aug 2012
    #4742
    Quote Originally Posted by shaq1968 View Post
    Take some close-up photos and post it here.
    Aug 2012
    #4743
    Para sa mga gusto mag-try ng Meguiar's product.
    Meg's Sulit Pack
    1 x 177ml Meg's Ultimate Liquid Wax
    1 x 177ml Meg's Ultimate Quik Wax Spray
    1 x Meg's Gold Class Rich Leather Cleaner-Conditioner Wipe
    1 x Meg's Yellow foam applicator pad
    Meg's Sulit Pack
    Jan 2013
    #4744
    ayos! pagtapos ko magwax (step 2) bigla umulan!
    Mar 2015
    #4745
    Quote Originally Posted by bhongchel View Post
    Haha, same here kahapon. Pagkatapos ng cleaner wax session ko umulan din. Wala pang LSP, ulan agad.
    Jan 2013
    #4746
    Quote Originally Posted by DarkMatter View Post
    hay! dibali natuyo ko na uli bukas step 3 na ko.
    Aug 2014
    #4747
    Quote Originally Posted by red_one View Post
    Eto pics bro. Para siyang nag smudge na slots.
    Apr 2011
    #4748
    Claying sir tangal yan. suggestion ko Mothers clay bar. 1.2k or 1.3k ata un.
    Aug 2014
    #4749
    Ah talaga. Pano ba i apply yung clar bar?
    Aug 2014
    #4750
    *clay bar. Nakita ko na sa ypu tube mukhang madali lng. Ttry ko nga. Thanks bro
    Jul 2015
    #4751
    Looks like early stages of clear coat failure, but I hope I am wrong, you can still try claying and see if this will do the trick, another option is a KAIO, this is a non-abrasive paint cleaner. Hope this helps
    Aug 2012
    #4752
    Ang laki ng area affected pala. Iba na color. Gaano katagal na yan? Do you wax your car regularly? It does look like clear coat failure. Pag clear coat failure, repaint lang ang solution. Claying will only remove surface contaminants and will not fix paint issues. I suggest bring it to a detailing shop for 2nd opinion.
    Aug 2014
    #4753
    Mga 3 months ago lumabas yan e. Any affordable detailing shop here in bf paranaque or makati?
    Jul 2015
    #4754
    Try ARC automotive sa my chino roces ata yan, as sir red_one said, just get their proffesional opinion, if it is indeed a clear coat failure, kase kung clear coat failure yung situation, hindi na kaya ng detailing, repainting will be your only option.
    Sep 2014
    #4755
    which is better Optimum Car Wax or Sonax High Speed Wax?
    Jun 2004
    #4756
    Haven't tried those except Optimum GPS.
    Sep 2014
    #4757
    Quote Originally Posted by venerzky View Post
    this is the Glaze Polish and Seal right? does it have the same function to the products I mentioned?
    Thank you for your feedback.
    Jul 2015
    #4758
    Quote Originally Posted by iSIDro View Post
    I have only used Optimum Car wax, so if you are looking for wax that is relatively easy to use fast to apply and durable enough to protect your car (2-3weeks), you may enjoy using OCW, but take note that it doesn't bead as much as our traditional wax.
    Sonax High Speed Wax is not that popular internationally, but their Sonax Brilliant Shine detailer is. But the later product does not provide UV protection, and it is meant only to support existing wax by providing insane hydrophobic properties (almost similar to a coating) that may last 2-3 weeks.
    So if you are looking for dependable protection that is easy to use, OCW will best fill your needs.
    Aug 2004
    #4759
    for light colored car like Flaxen or Silver, anong wax pinaka maganda ng gloss and shine?
    currently using Klasse SG then top with Collinite 845.
    Nov 2014
    #4760
    Sakin sir metallic silver pinakamaganda shine is yung megs nxt tech wax 2.0.. Natry ko na 845 and 3m quickwax as well as mega ultimate paste pero iba dating ng metallic silver sa nxt tech 2.0 talaga
"Tamang OC lang" - a newbie's guide to car appearance maintenance
