Results 1 to 8 of 8
    our helper mistakenly applied rubbing compound instead of wax , how will i remove the swirl marks?....
    thanks. :confused:
    tingin ko dapat dyan detailing..
    sugod kila theveed. ;)
    jojoico: Diba dati pa tong question? just wondering... basically you'll need to remove the haze caused by the compound... including the fine scratches a compound creates by using a polish.
    yes, nagbaka-sakali lang kung may over the counter product para pde DIY. mukhang pupunta nga ako sa shop nyo.
    detailing gurus,
    after you have your car detailed, say 3step with sealant? how do you mantain it? do u still need to wax it everynow and then or pa wash-wash nlang? until when? sabi kasi sealants can lasts up to 3months...ata
    how do you keep the sealant from getting stripped.... para tumagal?
    txs...
    crossback,
    First step in maintenance would be to get hold of a good shampoo. Wash regularly with shampoo. You could apply a thin layer of pure wax (no cleaners) so that it will serve as the sacrificial layer. Cleaner wax, detergents, soap and cheap quality shampoos will strip the sealant. Hope this helps.
    ano po ang cheapest that u would consider a good shampoo po? tnx
    txs blackmagic!
    for the shampoo.... any brand you can recommend! baka pumalpak ako ng mabili...sayang naman yung sealant ko!
    also, ok lang ba magapply ng QD spray on top of the sealant!
swirl marks caused by rubbing compund
