guys help me!! nalagyang ng stain ng mghty bond un body ng kotse ko., di ko alam kung anu solution ang ilalagay ko para matangal., itry un solution na remover ng mighty bond pero ndi parin natangal., even gas., ayaw pa din!!![]()
natuyo na?
di na rin ata kaya yan ng super glue remover, baka tamaan pati paint. kung maliit lang, just leave it as it is. pero kung malaki, baka kailangang i-paint over... dunno ha?
di na kaya ng super glue remover? did you let it soak? kasi yung sa car ko tagal na meron drop ng super glue nakaya pa din tanggalin ng remover e, cotton bud lang with rempver gamit ko.
Yun mighty bond kasi tinutunaw nya kung ano man yun malagyan mo. You may have to sand it off and kung natunaw nga yun paint kailangan mo pa touch up, then wet sand ulit para pumantay yun kulay.
Minsan nahahabol pa sa light sanding.
mighty talaga yan! even sa skin sandpaper ginamit ko.
nadikitan din kasi ako ehtama si boss otep, very light
sanding with h20 then habulun mo sa wax.
If all things fail, try:
1. High-set hair dryer to crumble the mightly bond.
2. when it crumbles, it'll come off.
Not sure. naisip ko lang. hehehe
may remover yan..
if i remember correctly, somebody asked about that some time back.. same problem.
try to get the glue remover first. kung ayaw, you might resort to a more abrasive solution. last resort na 'to though: wet sanding.
