Tsikot Waterless Car Wash Video Demo
http://www.facebook.com/album.php?ai...9958917&ref=mf
Before and After Pictures
WHY WE’RE HERE?
• Water crisis is getting worse every year
• Water reservoirs running low
• Lack of water supply in several communities
• El Niņo is here to stay
WHO WE SERVE?
• You live in a flat or a condo that doesn't allow you to use a hose or bucket of water to clean your car.
• You own a showroom that sells new or second hand car and don’t want to wet your floor.
• You need to go out and your car is a bit dirty but don’t want to waste money and water to go to car wash.
WE’RE A LITTLE BIT DIFFERENT AREN’T WE?
NO WATER. JUST SPRAY-WIPE-BUFF!
TSIKOT WATERLESS Carwash Solutions is not a car wash service, as you know it because there’s no water required in cleaning your car. This green innovation product will clean and polish your vehicle’s bodywork, glass and wheels without water. It contains premium soaps, surfactants, lubricating agents, and coco-based wax with polymer formula in cosmetic grade.
With just “spray-wipe-buff” you’ll get a clean and shiny car. But it doesn’t only do the carwash; it also takes care of our environment.
To Use:
Step 1. PRE-CLEAN
Gently wipe over the bodywork with a feather duster to remove dust, loose dirt and contaminants.
Step 2: SPRAY
Apply TSIKOT WATERLESS Carwash with an even mist, one section at a time, and allow a few seconds to penetrate.
Step 3: WIPE & BUFF
Use a microfiber towel to wipe off dirt and fresh contaminants. Then switch to a clean, folded, dry microfiber towel. Buff dry to a brilliant shine.
PRODUCT LINES:
TSIKOT WATERLESS CARWASH + POLISH
WATERLESS CARWASH 380 mL is ideal for personal and commercial use. If you live in a flat and cannot use a hose or if you operate a car showroom and have no desire to move a car or wet your showroom floor...we have the solution! just “spray-wipe-buff”. It contains premium soaps, surfactants, lubricating agents, and coco-based wax with polymer formula in cosmetic grade. It’s safe for your skin, on car paints and to our environment.
STEPS:
1. Gently wipe over the bodywork with a feather duster to remove dust, loose dirt and contaminants.
2. Apply TSIKOT WATERLESS Carwash with an even mist one section at a time and allow a few seconds to penetrate.
3. Use the microfiber towel to wipe off dirt and fresh contaminants. Then switch to a clean, folded, dry microfiber towel. Buff dry to a brilliant shine.
*Repeat steps 2 & 3 until vehicle is clean.
380 mL=10-15 carwashes = save BUCKETS of water
ALSO GOOD FOR MOTORCYCLES & BICYCLES.
TSIKOT WATERLESS GLASS CLEANER
WATERLESS GLASS CLEANER is the fastest way to clean your winshield.No need to bring buckets of water and other cleaning materials...just “spray-wipe-buff”. You won’t find harmful ingredients such as solvents and Volatile Organic Compounds (VOCs) in this glass cleaner, making it safe to use on treated windows and even glasses – helping to conserve the environment.
STEPS
1. Gently wipe over the windshield with a feather duster to remove dust, loose dirt and contaminants.
2. Apply TSIKOT WATERLESS Glass Cleaner with an even mist one section at a time and allow a few seconds to penetrate.
*Repeat steps 2 & 3 until glass is clean.
380 mL=10-25 GLASS PANEL/CAR=save BUCKETS of water
ALSO GOOD FOR glass, mirrors, plexiglass, tinted windows, light fixtures, crome and acrylic.
TSIKOT WATERLESS TIRE + ENGINE CLEANER
WATERLESS TIRE CLEANER is the quickest way to clean your tires and your engine too. No water needed...just “spray-wipe-buff”. This is an advance degreaser designed to remove common soil and oil deposits on your engine, under chassis, tires and your hub fender. It can be applied using a brush and cloth rug. Tough on dirt, but gentle on the environment.
STEPS
1. Apply TSIKOT WATERLESS Tire Cleaner, wet thoroughly and allow a few seconds to penetrate.
2. Gently brush or wipe off dirt and fresh contaminants. Just clean one section at a time.
3. Switch to a clean, folded, dry cloth then buff dry.
*Repeat steps 1, 2 & 3 until tire is clean.
380 mL=10-25 CLEAN TIRES=save BUCKETS of water
NOW AVAILABLE at TSIKOT SHOP Taguig *P750 per set. Free product demonstration everyday between 9 to 5pm except tuesdays
P395 waterless car wash
P295 glass cleaner
P295 tire cleaner and engine degreaser
much better pasyal ka dito sa shop sir... palinisan ko kotse mo
