Page 6 of 7 FirstFirst ... 234567 LastLast
Results 101 to 120 of 122
    Oct 2016
    #101
    Quote Originally Posted by jedi View Post
    Tsikot Waterless Car Wash Video Demo
    Facebook - Log In or Sign Up
    Before and After Pictures
    WHY WE’RE HERE?
    • Water crisis is getting worse every year
    • Water reservoirs running low
    • Lack of water supply in several communities
    • El Niño is here to stay
    WHO WE SERVE?
    • You live in a flat or a condo that doesn't allow you to use a hose or bucket of water to clean your car.
    • You own a showroom that sells new or second hand car and don’t want to wet your floor.
    • You need to go out and your car is a bit dirty but don’t want to waste money and water to go to car wash.
    WE’RE A LITTLE BIT DIFFERENT AREN’T WE?
    NO WATER. JUST SPRAY-WIPE-BUFF!
    TSIKOT WATERLESS Carwash Solutions is not a car wash service, as you know it because there’s no water required in cleaning your car. This green innovation product will clean and polish your vehicle’s bodywork, glass and wheels without water. It contains premium soaps, surfactants, lubricating agents, and coco-based wax with polymer formula in cosmetic grade.
    With just “spray-wipe-buff” you’ll get a clean and shiny car. But it doesn’t only do the carwash; it also takes care of our environment.
    To Use:
    Step 1. PRE-CLEAN
    Gently wipe over the bodywork with a feather duster to remove dust, loose dirt and contaminants.
    Step 2: SPRAY
    Apply TSIKOT WATERLESS Carwash with an even mist, one section at a time, and allow a few seconds to penetrate.
    Step 3: WIPE & BUFF
    Use a microfiber towel to wipe off dirt and fresh contaminants. Then switch to a clean, folded, dry microfiber towel. Buff dry to a brilliant shine.
    PRODUCT LINES:
    TSIKOT WATERLESS CARWASH + POLISH
    WATERLESS CARWASH 380 mL is ideal for personal and commercial use. If you live in a flat and cannot use a hose or if you operate a car showroom and have no desire to move a car or wet your showroom floor...we have the solution! just “spray-wipe-buff”. It contains premium soaps, surfactants, lubricating agents, and coco-based wax with polymer formula in cosmetic grade. It’s safe for your skin, on car paints and to our environment.
    STEPS:
    1. Gently wipe over the bodywork with a feather duster to remove dust, loose dirt and contaminants.
    2. Apply TSIKOT WATERLESS Carwash with an even mist one section at a time and allow a few seconds to penetrate.
    3. Use the microfiber towel to wipe off dirt and fresh contaminants. Then switch to a clean, folded, dry microfiber towel. Buff dry to a brilliant shine.
    *Repeat steps 2 & 3 until vehicle is clean.
    380 mL=10-15 carwashes = save BUCKETS of water
    ALSO GOOD FOR MOTORCYCLES & BICYCLES.
    TSIKOT WATERLESS GLASS CLEANER
    WATERLESS GLASS CLEANER is the fastest way to clean your winshield.No need to bring buckets of water and other cleaning materials...just “spray-wipe-buff”. You won’t find harmful ingredients such as solvents and Volatile Organic Compounds (VOCs) in this glass cleaner, making it safe to use on treated windows and even glasses – helping to conserve the environment.
    STEPS
    1. Gently wipe over the windshield with a feather duster to remove dust, loose dirt and contaminants.
    2. Apply TSIKOT WATERLESS Glass Cleaner with an even mist one section at a time and allow a few seconds to penetrate.
    *Repeat steps 2 & 3 until glass is clean.
    380 mL=10-25 GLASS PANEL/CAR=save BUCKETS of water
    ALSO GOOD FOR glass, mirrors, plexiglass, tinted windows, light fixtures, crome and acrylic.
    TSIKOT WATERLESS TIRE + ENGINE CLEANER
    WATERLESS TIRE CLEANER is the quickest way to clean your tires and your engine too. No water needed...just “spray-wipe-buff”. This is an advance degreaser designed to remove common soil and oil deposits on your engine, under chassis, tires and your hub fender. It can be applied using a brush and cloth rug. Tough on dirt, but gentle on the environment.
    STEPS
    1. Apply TSIKOT WATERLESS Tire Cleaner, wet thoroughly and allow a few seconds to penetrate.
    2. Gently brush or wipe off dirt and fresh contaminants. Just clean one section at a time.
    3. Switch to a clean, folded, dry cloth then buff dry.
    *Repeat steps 1, 2 & 3 until tire is clean.
    380 mL=10-25 CLEAN TIRES=save BUCKETS of water
    NOW AVAILABLE at TSIKOT SHOP Taguig *P750 per set. Free product demonstration everyday between 9 to 5pm except tuesdays
    P395 waterless car wash
    P295 glass cleaner
    P295 tire cleaner and engine degreaser
    Hey how would this work with no water and since there is no water does it make streaks or scratches
    Quote Originally Posted by isaac williams View Post
    Do Waterless Car Washes Scratch Paint? Chemical Guys EcoSmart - YouTube
    Aug 2014
    #103
    Have any of you tried AutoGard Waterless Carwash?
    Sep 2011
    #104
    OT
    Sent from my C1905 using Tsikot Forums mobile app
    Dec 2017
    #105
    Re: Do Waterless Car Washes Scratch Paint? Chemical Guys EcoSmart - YouTube
    I'd be skeptical. They never showed the finish under a strong light. I'd bet there will be tons of swirls. lol
    Obviously, they are selling stuffs. So, caveat emptor.
    Re: Feather duster
    Yikes! Even with best feather duster with wax and all, swirls swirls swirls scratch everywhere.
    If the car has just been washed and after a few days it gets dusty or with light dirt on it, I would simply hose it down and pat dry it. No wiping. Besides, my car has been sprayed with Meguair's UQD, so, water beads off easily and dust/light dirt simply slide away. 15-20 mins tops for the whole work. Then full car wash every fortnight or every week if the car is dirty.
    May 2017
    #106
    how about using California Car Duster as light as possible?
    ONR?
    Quote Originally Posted by brushless View Post
    Re: Feather duster
    Sep 2006
    #107
    Have been using the Microtex car duster everyday for some time now. And yes, I try to wipe as light as possible. No obvious swirls so far.
    #108
    I've been a California Duster and Microtex duster user for many years as well (even on black cars). No swirl marks but I do wax the car regularly and make sure i always dust off in one, consistent motion/direction.
    Aug 2009
    #109
    I find that the microtex duster is handy on light dusts only. If the vehicle sits in the garage for a couple of days, its going to accumulate a thicker amount of dust. I'd rather hose it down quickly and wipe with a detailer. Ran out of instant detailer and now waiting for the ONR I ordered.
    Sent from my ASUS_Z00ED using Tsikot Forums mobile app
    Dec 2017
    #110
    Re: California Duster
    If it's only light dust I wouldn't bother. It will just fly off once you drive your car anyway, right? If you dust, it will just come again at the end of the day and you dust over and over again. So much work and you are already accumulating swirls. OCD inducing, hahaha. Just let the wind do it for you when you drive. California dusters are only for light dusts and not for stubborn pollution films. They are people who have complained of scratches and swirls when using this product. If you attempt to dust off the black pollution film when you thought it's just dust, swirls swirls scratch everywhere. If you run your finger on the car and it's black and gritty or powdery to the feel, that's pollution film, step away from the car or you'll be tempted to dust it. lol!
    Re: ONR
    For ONR, I think many people assume its totally fine for dirty cars. Yikes! It's only for light dirt. I can always hose it down and pat dry. Same thing. lol
    I think all this water saving method like two buckets and rinseless wash and such came to be because of California's strict laws on wasting water. That's $500 fine right there where it hurts. But, we are in the Philippines.
    Anyway, for me,
    1) If light dust, I won't bother. I let the wind do it for me when I drive.
    2) If dust/pollution film is building up, wind can't blow this off from the car, so I hose it down and pat dry.
    3) If the car is dirty with some nasty stuffs, no amount of hosing will do it, so it's car wash time on the weekend. At least 3 hours dedication of love and devotion - pressure washer, foaming, leaf blower, UQD, etc. You know the drill.
    May 2017
    #111
    For light dust... yes I use california duster and it seems to lift off the dust from the car in one steady direction/motion.
    Pollution Film.... is it bad to keep it in the car for a long time before washing? You don't really notice it naman kasi especially on a darker colored car and I'd rather minimize the frequency of washing/drying because they also cause swirls/scratches.
    What irritates me is the when i wipe the dust off from the glass windshield/windows... whether it's the california duster or a normal feather duster, they seem to be moist and spreads around and creates haze. so after dusting, i usually use glass cleaner pa to wipe them off.
    Re: ONR
    Anyway, for me,
    #112
    Anyway, for me,
    After doing item No. 3, it rains.
    Dec 2017
    #113
    Quote Originally Posted by Shutterbug View Post
    Not necessarily. But, when it rains, this is one of the main causes of unsightly watermarks as the water dries off. You'll have it all over your car. Remember, rain is slightly acidic and will react to whatever compound that is in the pollution film. The longer you leave your car with watermarks, the more damage it will do to your paint. It's a nasty concoction. So, better keep watch of the weather.
    For me, rain or shine, I keep it hosed down when pollution film accumulates to keep the car looking like new. Pollution film will make you car look dull. All those effort in washing the car will simply go to waste. grrrr! lol.
    You will notice it under the sun and bright light at a certain angle. Even more when someone just ran their fingers on it. But, it will camouflage under a shade or cloudy days. lol
    Yes, of course, frequent washing/drying will accumulate swirls and scratches no matter what method you use. What we are doing here is "minimizing" as best as we can. That's why I only hose it down and pat dry when pollution film accumulates. No wiping. No way. I also keep my car washing day to a minimum, every two weeks or during the week if the car is really dirty.
    That's morning condensation. It will evaporate once the sun is up. Better to do it in the afternoon or evening.
    Dec 2017
    #114
    Or bird poop. Hahaha!
    I won't mind if it rains daily. No dust and pollution film to worry about. Water will just bead off from my car. But, those days with short rain duration and suddenly the sun is at full blast, that's something to watch out for because of those nasty watermarks.
    Mar 2017
    #115
    Where can i buy ONR or UWW?
    Apr 2012
    #116
    Quote Originally Posted by xnxnxn View Post
    check mo olx o lazada, o kaya ask/pm mo si sir Ginnova
    #117
    Visit my website. REFLECTIONS CAR CARE. Both products are available
    Sent from my SM-G610Y using Tapatalk
    Mar 2017
    #118
    Whats the difference between aftermarket and the regular one aside from price?
    #119
    All my onr are in gallon sizes. Original 32oz bottle tends to leak out during shipment from US to Ph. For those opting for smaller sizes, we can repackage them into leak proof bottles.
    Dec 2017
    #120
    My brother bought this for me. Easy to use and I think the effect wears off easily too. I'm thinking of buying a new wax but it's a hassle to apply it compared to this one.
    Anyone's have tried this? What's your observation / recommendation?
Spray-Wipe-Buff Waterless Car Wash
