Forums
Discussions
Events
Community
January 17th, 2003 05:00 PM
anong gagamitin ko na sandpaper para mapantay ko yung touch uppaint?
after that polish dba?
also what is the best way to apply touch up paint?
January 17th, 2003 05:21 PM
Are you proficient with sanding?
Understand that after sanding, you'll have to compound and polish after as well...
3 or so swipes with a sandpaper (even if you use 2000 grit) can pretty much scrape all the clear off your surrounding area... don't say i didn't warn you... ;)
Anyway, if you really wanna try, read these...
http://www.web-cars.com/detail/touchup.html
http://www.paintscratch.com/automotive-paint-tips.htm
January 19th, 2003 01:02 AM
i plan to have it repainted kasi. so i though this would be a good oportunity.
January 19th, 2003 01:09 AM
san makakanili ng nick sander?
mga how much kaya yun?
January 20th, 2003 11:08 AM
sa states mura lang, not sure kung meron dito, you might wanna ask paint shops for fiberglass tipped pens.
January 20th, 2003 11:10 AM
fiber glass tip pens? what doe sit look like?
also what rubbing compound should i use? how much do they cost?
