Results 1 to 18 of 18
    Dec 2004
    good day to all tsikoters... a lot has been said about the steps done in strip to metal painting and "wash over" (hilamos) painting. Once and for all pwede kaya share nyo ang tamang procedure para d tayo maloko ng mga pintor? if posibble please share your thoughts if pwede ba paghaluin and acrylic and urethane based paints? maraming salamat po...
    as the name implies, strip to metal means alisin lahat ng paint primer etc hanggang lumabas ang metal, while wash over is papatungan lang yun existing paint mo.
    but a lot of oldtimers believes na mas masama magpa strip to metal unless bulok na talaga kasi mas maganda pa rin ang primer na ginawa ng factory
    Dec 2004
    * shadow, maraming salamat po sir sa quick reply nyo. kasi recently, nagpa wash over po ako. strip to metal ang hood, roof and trunk. in short, inistrip tapos nilagyan ng primer na urethane, niliha tapos masilya. yung sides naman po e walang tama kaya di na ini-strip. niliha lang, apply masilya sa mga uneven portions tapos spray na ng based paint (acrylic) (of course he observes curing period for every procedure). dapat po bang lagyan ng primer yung sa sides ko bago base paint para mas maganda ang kapit ng wash over paint? plano po ng pintor acrylic ang base paint (acrylic din kasi ang paint ng car ko) tapos ang finishing is urethane. ano po ang magiging problema kung sakaling meron. please help din po mga tsikoters, need your inputs badly... kasi po as of now pina-stop ko po ang work...
    Quote Originally Posted by Firefox View Post
    * shadow, maraming salamat po sir sa quick reply nyo. kasi recently, nagpa wash over po ako. strip to metal ang hood, roof and trunk. in short, inistrip tapos nilagyan ng primer na urethane, niliha tapos masilya. yung sides naman po e walang tama kaya d na ini strip. niliha lang, apply masilya sa mga uneven portions tapos spray na ng based paint (of course he observes curing period for every procedure). dapat po bang lagyan ng primer yung sa sides ko bago base paint para mas maganda ang kapit ng wash over paint?
    don't worry tama naman ang ginawa sa oto mo...
    Dec 2004
    good morning to all... your inputs will be highly appreciated.. thanks...
    Dec 2004
    Up lang po. Sir Theveed any ideas, sir? thank you in advance...
    Aug 2008
    mga papa pa-ride na rin, i hope this is not an OT, pacensya na po.
    ano po ang masasabi nyo with regards to using acrylic vs. urethane paints? mas tatagal po ba ang isa dito over the other? TIA.
    Dec 2004
    Quote Originally Posted by hakkinen View Post
    sir hakkinen, as far as i know mas durable ang urethane matagal din po ang preparation and of course mahal vs acrylic.
    Apr 2009
    gusto ko sanang mag change color sa otto ko. adviseable ba kung wash over lang? o mas mabuti maintain same color nalang? ano ang disadvantages ng change color?
    Dec 2004
    sir joey, i think number 1 consideration is the cost plus the hassle in the documentation: clearance, affidavit, stencil, etc...
    http://tsikot.yehey.com/forums/showthread.php?t=13080
    Apr 2009
    tama si FireFox. Hassle talaga magpa change color. Daming documentation requirements. Best pag wash over, same color nalang. it would still look new naman. Alagaan nalang.
    Dec 2004
    sir david, thanks for your approval
    sir Proximo, salamat po sa very informative link. sana mabasa din po ng iba bago sila magpa wash over...
    Apr 2009
    babaguhin ko sana color ng civic ko but after reading this long thread, I think I am convince na wag nalang. Salamat sa mga posting ninyo Firefox, David at iba pa.
    Dec 2004
    Quote Originally Posted by CODE RED View Post
    sir code red, kung maayos naman po ang paint nyo imho leave it that way, kung wala po kayong makitang magaling na pintor masakit sa ulo, secondly, masakit din sa bulsa ang magpa change color (3k kung paayos mo sa iba, mga 2k kung ikaw personally mag asikaso).
    perhaps you may consider detailing na lang po.
    Apr 2009
    Salamat muli sa payo. Papatingnan ko nalang muna sa Meg o Mothers. Baka nga detailing lang ang kulang.
    Jul 2019
    Noob ako dito sa Tsikot, pero ang dami ko ng napupulot na info. When is detailing better over washover? Sa case kasi ng 2003 Camry ko, may konting nag-chip off na orig paint sa front bumper at sa gilid, near the doors. Yung paint di naman totally nag-chip, parang nagkaroon lang ng maliliit na spots. Wala namang kalawang pa. Makakaya pa kaya ng detailing ito?
    Jun 2005
    Quote Originally Posted by oldcamryguy View Post
    Paint chip, need touch up paint.
    Detailing is a fancy name for cleaning, polishing and buffing the car. It will not remove scratches or chipped paint
    Sent from my MI MAX 2 using Tapatalk
What are the Steps in Strip to Metal painting and "wash over" painting
