Results 1 to 11 of 11
    Jan 2011
    Hi Everyone,
    I had my sound deadening mat removed inside my trunk since it was so heavy and trunk wont open automatically unless you use the keys. I used a hair dryer to soften the mat and gently scraped off the mat using a plastic scraper so as not to damage the paint. It was a successful attempt but the adhesive residues are still present and i don't have any idea on how to remove it.
    Is there a way to remove it DIY? or i have to bring it to a detailing shop? Please advise, your inputs are greatly appreciated. Thanks and more power!
    Jan 2010
    Subukan mo yung WD-40, or mga adhesive remover sa Concorde, True Value, at Ace Hardware.
    Jan 2011
    ah meron palang nabibiling adhesive remover..i'll give it a shot this weekend hopefully matanggal ang panget kasi sa loob ng trunk. maraming salamat sir!
    Feb 2010
    ingat lang sir sa 3m adhesive remover
    nakakasira ng paint yun HTH
    Feb 2010
    Feb 2009
    if your objective is to cover up the eyesore, how about covering the adhesive with wall paper to match your paint or your car's interior
    Jan 2009
    baby oil and soft cloth or cotton balls?
    Jan 2011
    Maraming salamat sa mga suggestions..much appreciated!
    Tried WD-40 kanina, ok naman masakit lang sa braso magkaskas pero natatanggal naman. Paint is ok parang walang nangyari di ko pa nga lang natatapos masakit na braso ko eh.
    subukan ko mamaya yun baby oil and basahan kasi baka pag bulak bka dumikit.
    Quote Originally Posted by eboitot View Post
    panu sya nakakasira..as in masusunog yun pintura? salamat sa tip sir!
    Mar 2005
    butly based ba yung sound deadening mats mo? Try using kerosene
    May 2010
    Try 3M rubbing compound. it works.
    Mar 2005
    Or magpalit kayo ng deadening material na mas magaan para bumukas pa din trunk niyo.
Adhesive Residue Removal - Need Help
