Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    I havn't had my truck washed for 2 weeks now due to the continuous rains. Problem is dumikit na sa body ang dirt and cannot be rinsed by water pressure alone. Na trauma na ako during my last car wash wherein nagasgas and paint ko because of improper rinsing. The idea is to remove the dirt muna before shampooing right? Do I do this with a sponge and water or can I use my hand (while rinsing with water) in removing this?
    Thanks.
    Err... mukhang mali pre ang gamit mong mga tools to wash your car.
    Sponge / barehands isn't a good idea. Use a wash mitt for shampooing & microfiber towels for drying. And get a good shampoo (tulad nung sa Big Bert's).
    For an extra muddy vehicle... I just soak the vehicle 15 minutes before to soften up the dirt.
    Feb 2005
    The dirt can be removed by strong burst/streams of water from a power washer. However, it would depend on how much psi that power washer can churn out.
    One thing's for sure: don't wipe of the dirt even if your truck has been soaked with water because it will definitely ruin your paint.
    Good luck.
    Jan 2003
    Quote Originally Posted by nicolodeon
    ...ingat lang, powerwashing with the dirt still clinging on the vehicle would give you a sandblasting effect.
    May 2004
    agree with the two posts by M2 & nico. don't wipe it coz it will definitely scratch the paint.
    shower muna your ride para medyo lumambot ang dirt. pag medyo malambot na, pressure washer mo. after washing, ituloy mo ng detail.
    just a tip. kahit everyday umuulan. i always make sure that when i reach home at night, pinag shower ko ride ko. just to remove the dirt or para wag dumikit. the following day na lang ang wiping & QD.
    good luck bro!
    [QUOTE=silhouette]
    just a tip. kahit everyday umuulan. i always make sure that when i reach home at night, pinag shower ko ride ko. just to remove the dirt or para wag dumikit. QUOTE]
    korek!
    ako, 2 days lang... body wash na ulit. ;)
    Thanks for the tips!
    mazda,
    WHat do you mean by soaking it 15 mins before?
    clay bar is your friend
    Feb 2005
    Quote Originally Posted by M54 Powered
    sir, para san po ang clay? anong brand ang ok at affordable?
    thank you!
    Quote Originally Posted by BlackPrince
    thank you!
    check out the detailing thread.. there's an extensive discussion over there.
    Feb 2005
    Quote Originally Posted by dehadista
    sorry, tinamad mag search mwahahahaha .. thank u sir!
    Feb 2005
    I think M2 means that you sop-up your truck with water. Let the water stay for 15 mins. (soaking it up) to soften then, like what Silhoutte said, when the dirt softens up, spray it with strong streams of water using a pressure washer set to a high psi.
  13. #13
    Djerms:
    - Get a bucket of water
    - put lots of car shampoo in it
    - get your trusty wash mitt and slowly wipe of the dirt, dont rub it tho
    - wipe in a straight line not in a circular motion, make sure you get lots of car shampoo on the washmitt for added lubrication
    - work your car per panel meaning soap one panel then rinse then so fort
    - NO, I don't think power washing it is a good idea, it might scratch/damage your paint
    - if you feel a lot of contaminants sticking on your paint after wash, clay it.
    May 2005
    Quote Originally Posted by ILuvDetailing
    Djerms:
    Sir meron ba ibang alternative sa 'wash mitt for shampooing & microfiber towels for drying?' mahal kasi eh.. meron po ako maliit na car wash business.
    Jun 2005
    Quote Originally Posted by espeago
    hi, san ba nakakabili ng microfiber towels at wash mitt anong brand ang recommended niyo?
    thanks.
    Oct 2004
    waaah ako ang dumi na. Dapat kanina iwash ko pero dami ko ginawa. Galing pa naman outing yun at 1 week ko na sha hindi nalilinis waah!
    Feb 2003
    yup, take it from IluvDetailing, pressure washing is a no-no, the strong burst of water can actually scratch your paint...
    1 week kong di nahugasan yung car and walang wax, yesterday i washed it, and used 2x the amount of Big Bert's shampoo than the usual. ayos naman, walang new scratches, then nag 2-step ako, ayun daming dumi nung nag paint cleaner ako kahit na 2x ko nang hinugasan yung car. buti na lang ngayon protected na... well until next week that is.
    you should really wash and detail more often in the rainy season.
    question po? ano po yung 2-step detail or 3-step details na madalas kong nababasa?
    Jan 2004
    sir, 3 step means: paint cleaner wax, then glaze, then carnuba.
    Share ko lang. There's a new detailing shop sa may julia vargas in Ortigas home depot (Car depot). Ok ang car wash, they use microtowels for drying and wash mits for soaping.. Medyo pricey lang at 150.00 kung with vacuum. Pero they will decrease their price to 90.00 daw for suv's once nagawa na yung bar nila sa 2nd floor. Haven't tried their detailing service yet but I saw their works in other vehicles..ok naman.
    ...#1 pa rin sakin ang Big berts pero sobrang layo sa amin. ..if only they branch out....here in Ortigas CBD
Removing dirts and grime before car wash
