Results 1 to 20 of 35
    Hello po mga boss,
    I just have my car serviced at prens to replace the valve cover gasket, ito ang loob ng makina,maitim siya compared sa mga commercial ng tv hehe, sabi ng mekaniko kailangan daw i flushing para matangal ito. sinubukan namin tangalin at lumabas naman yung kintab ng metal parts. ang tanong ko lang ay:
    1. how effective is flushing the engine to remove the black oil that covers the metal parts?
    2. if flushing is the best way,what brand, how much liters of oil is needed for the process?
    3. pwede ba ito maging effect ng oil na gamit ko? my oil is Apex semi synthetic / SAE 15w/50 (fortified with pertua oil additive). do i need to switch to imported oil?
    naka 22K km na po ang kotse since last oil change, ride is civic 99. hope to hear some inputs sa inyo. TIA
    hello po mods,
    Sorry, hinde ko napansin ang section, paki move na lang sa workshop. thanks.
    22k since your last oil change? masyado na atang matagal yan. at the most 10k. Those black oil coating are the ones that protect your engine during start-up. peor nun sinabi mong 22k eh baka sludge na yan mga black patches sa engine components mo....hehehe.
    Jan 2003
    use motul engine flush. sa diesel hiace ko yun ang ginamit, then tecma mega oil. ganda ng hatak, at tuno bago yung makina
    Jun 2007
    how often po ba dapat magpaflush ng engine?
    Quote Originally Posted by impulzz View Post
    thank you sir. meron bang equivalent ito para sa gas engine? gaano katagal i flush? i.e. 10mins engine at idle? then drain? thanks.
    Quote Originally Posted by afrasay View Post
    yup 22K km na. kaya due na ako for an oil change,yung apex oil na gamit ko originally red in color kaya palaging napapagkamalan na madumi na yung oil.thanks
    impulzz, san ka nakabili nung tecma mega oil? how much ang 1 liter?
    Yes, kelangan ng flushing nyan and maybe you need to use 2 cans instead of just 1 dyan sa engine mo.
    ok yung "Top 1" brand na engine oil, meron silang regular at may fully synthetic.
    Then take it from here, make sure you do regular check-up ng ride mo, most especially nga yang engine oil.
    Jan 2003
    n5110, kung malapit ka sa araneta, look for stage 1 motorworks ( www.s1motorworks.com ), look for gilbert or harry, dun ko pinagawa yung sa oto ko. malaki differnce ng motul flush sa flushing oils ng mga caltex or low end oils. Dati gamit ko clatex flushing oil, but nung sinubukan ko motul, laki ng ginanda ng takbo ng makina. Just stay away from whiz, used it once umusok fx ko badtrip.
anu ang gagawi pag ganito kadumi ang mga loob ng makina?
