Results 1 to 15 of 15
    Jul 2010
    Sorry po hindi ko na nairotate tong picture.Gusto kolang po sana malaman kung paano tanggalin yan puti na pababa galing sa side mirror po.Yun car shampoo po yan.Mahirap po tanggalin e kahit punasan.
    Quote Originally Posted by Nuebe Siete View Post
    Ano bang 'mantsa' iyan, bro?...
    18.2K:soccer2:
    Jul 2010
    18.2K:soccer2:
    Sa car shampoo po yan.Pag tapos ko na linisan kasi pag gagamitin ko na car ko,sa may sulok o loob side mirror may naiipon pala tubig na may bula pa at nahuhulog pababa.pag natuyo na,hirap na tanggalin.
    Aug 2005
    Hindi na matatanggal yan. You have to live with it and accept that fact. Joke joke joke!
    This nasty residue happens after you wash your car and just dries it up with chamois or whatever your drier preference. But if you use a compressed air with nozzle to blow the inner body crevices, panel gaps and hard to reach areas, while wiping off the blown sprays, there is no way you would experience this dilemna.
    The side mirror housing usually creates this problem after you wash your car and subsequently dries it up manually.
    Water when left dry produces mineral deposits like so. A workaround to remove this is to use a scratch remover like the one manufactured my 3M. It is called 3M scratch remover. Apply a small amount on the affected area, gently rub the application with a clean/dry microfiber towel. Repeat step over and over until the marking is no longer visible. Follow it up with 3M hand glaze, polish with a clean/dry microfiber towel to restore that deep body colour. Top it up with your favorite wax, polish and you're on your way to a good night sleep. Hope this helps. Good luck.
    Feb 2013
    Black pa naman yun car mo you have to bring it sa detailer para maremove at mai-polish ng maganda kasi pag hand lang it will have swirl marks...
    I also have this problem. Ginagawa ko na lang is hipan ng malakas yung part na yan. Repeat hanggang wala ng tubig sa sulok. Talagang nag-aaccumulate ang tubig sa sulok na yan sir. One thing to note din is to rinse your car thoroughly and make sure walang car shampoo na matitira. Recipe for hard watermarks yan. And don't wash sa arawan.
    If may budget. Get one of these.
    matanong ko lang sir 97, ano pang detail meron ka na sa bahay? cleaner wax? polish? glaze? wax? paint cleaner (step 1)? swirl/scratch remover? any of these products can remove that shampoo mark with a microfiber and some effort, tanggal yan. yun lang, pag nalinis mo na yang part na yan, you have to do that to the whole door kasi baka magmarka naman yung makintab na part na nalinis mo, so kelangan mo na linisin/detail the whole door. tapos mapapansin mo, yung door na nalinis mo, mas makintab na kaysa sa ibang part ng car kaya dapat ma detail mo na the whole car.
    try mo rin yung formula one na scratch and swirl mark remover. yan ang ginagamit ko to detail my car and easily natatanggal niya yung mga ganyang mantsa.
    Apr 2012
    it's a watermark, hindi sa shampoo yan, hindi mo lang napupunasan ng maayos ang ilalim ng side mirror mo so tumutulo at natutuyo. kaya pa ng cleaner yan like Klasse All In One. kung nag etched na yung watermark sa paint ay pwede mo i polish ng swirl remover, by hand kaya yan pero mas madali lalo kung may polisher ka...
    Jan 2010
    Sir ano po tawag dyan? Meron po kasi ako nakita stanley, parang ganyan 3,300. Anu po kayang brand ang mas mura maliban sa manual mode using straw.
    Aug 2012
    that's a Black & Decker KTX5000 600W Variable Speed Blower. iba pang tawag is Electric Air Blower.
    Jul 2010
    Salamat sa mga reply po.Ang nasubukan ko palang WD-40, colgate white at mga wax pero ayaw pa din matanggal.
    Oct 2011
    sir, try mo wax or polish.
    Jan 2010
    Quote Originally Posted by red_one View Post
    Thank you sir.. search muna sa google para makakita ng murang brand. Balak ko sana is yung vaccuum sa ace hardware na na dual purpose.. Kaya lang parang mainit yung nilalabas na hangin.
    to remove that glass "stain", try colgate white. it's a very mild abrasive... parang metal polish ang gamit..
Paano po tanggalin ito?
