Sorry po hindi ko na nairotate tong picture.Gusto kolang po sana malaman kung paano tanggalin yan puti na pababa galing sa side mirror po.Yun car shampoo po yan.Mahirap po tanggalin e kahit punasan.
Hindi na matatanggal yan. You have to live with it and accept that fact. Joke joke joke!
This nasty residue happens after you wash your car and just dries it up with chamois or whatever your drier preference. But if you use a compressed air with nozzle to blow the inner body crevices, panel gaps and hard to reach areas, while wiping off the blown sprays, there is no way you would experience this dilemna.
The side mirror housing usually creates this problem after you wash your car and subsequently dries it up manually.
Water when left dry produces mineral deposits like so. A workaround to remove this is to use a scratch remover like the one manufactured my 3M. It is called 3M scratch remover. Apply a small amount on the affected area, gently rub the application with a clean/dry microfiber towel. Repeat step over and over until the marking is no longer visible. Follow it up with 3M hand glaze, polish with a clean/dry microfiber towel to restore that deep body colour. Top it up with your favorite wax, polish and you're on your way to a good night sleep. Hope this helps. Good luck.
I also have this problem. Ginagawa ko na lang is hipan ng malakas yung part na yan. Repeat hanggang wala ng tubig sa sulok. Talagang nag-aaccumulate ang tubig sa sulok na yan sir. One thing to note din is to rinse your car thoroughly and make sure walang car shampoo na matitira. Recipe for hard watermarks yan. And don't wash sa arawan.
If may budget. Get one of these.
matanong ko lang sir 97, ano pang detail meron ka na sa bahay? cleaner wax? polish? glaze? wax? paint cleaner (step 1)? swirl/scratch remover? any of these products can remove that shampoo mark with a microfiber and some effort, tanggal yan. yun lang, pag nalinis mo na yang part na yan, you have to do that to the whole door kasi baka magmarka naman yung makintab na part na nalinis mo, so kelangan mo na linisin/detail the whole door. tapos mapapansin mo, yung door na nalinis mo, mas makintab na kaysa sa ibang part ng car kaya dapat ma detail mo na the whole car.
try mo rin yung formula one na scratch and swirl mark remover. yan ang ginagamit ko to detail my car and easily natatanggal niya yung mga ganyang mantsa.
it's a watermark, hindi sa shampoo yan, hindi mo lang napupunasan ng maayos ang ilalim ng side mirror mo so tumutulo at natutuyo. kaya pa ng cleaner yan like Klasse All In One. kung nag etched na yung watermark sa paint ay pwede mo i polish ng swirl remover, by hand kaya yan pero mas madali lalo kung may polisher ka...
that's a Black & Decker KTX5000 600W Variable Speed Blower. iba pang tawag is Electric Air Blower.
Salamat sa mga reply po.Ang nasubukan ko palang WD-40, colgate white at mga wax pero ayaw pa din matanggal.![]()
to remove that glass "stain", try colgate white. it's a very mild abrasive... parang metal polish ang gamit..
