Results 1 to 17 of 17
    Apr 2004
    hi guys. I want to remove the conduction sticker in my ae111 but I dont know the best way (DIY) to remove it. Ano ano po ang mga kelangan?
    Aug 2005
    WD40 works fine for me.
    Spray along the side until it seeps through, a few minutes will do, then slowly peel it off.
    tama, wd40 or even dish washing detergent. basta wag ka gagamit ng matigas when scrapping it off, like steel scraper, screwdriver, coin, knife, scrubbing pad, etc at sigurado gasgas ang glass. if you need something to scrape it off, use your fingernails. at most use a piece of soft wood (popsicle stick) or soft plastic. hindi bale matagal at tumulo ang 1 gallon na pawis wag lang magasgas ang glass at 1 gallon na luha ang tutulo ehehehehe!
    May 2005
    yung basahan na nilagyan ng mainit na tubig tapos itapal mo..matatanggal sya.
  5. #5
    hotwater + small towel + globe prepaid cellcard lang kailangan mo. Soak the towel in hotwater, gentley wipe the towel over the conduction sticker, use the card to scrape of the sticker, dahan dahan lang.. HTH
    May 2005
    gaano ka hot yung tubig ? .. i've got some 2005 stickers that i want to take out ..
    use BLADE..
    Dec 2003
    Sa van namin ang ginawa ko kinukut ko at blade lang then water yun lang..Pero ang sakit nung kamay ko matapos ko kutkutin yung sa van namin na conduction sticker ang tagal na kase nun..
    Quote Originally Posted by gearspeed
    tama masakit nga lng sa kamay..pero nun natangal ko buo pa kaya dinikit ko na lng sa poste..hehehhe
    Mainit na tubig works for me. Patong ko bimpo sa ibabaw ng conduction, then buhos mainit na tubig.
    Iwan ko sandali. Pagbalik madali na alisin gamit plastic card (prepaid, etc.).
    May 2005
    I estimate your car is around 5-6 yrs. old so it would be safe to say that the conduction sticker has "melted" itself onto the glass surface. Once the conduction sticker has reached this phase/stage, it is going to be very difficult to remove it even with a sharp implement (a big no-no either way).
    Anyways, I tried using acetone, paint thinner, or even stronger petroleum based solvents (if needed). Try using the aforementioned solvents in conjunction with a blunt implement (eg. credit card, lollipop stick,etc.). Never use sharp implements such as blades, etc bec. they do more damage than good. After completely removing the sticker, clean up using isopropyl (not ethyl) rubbing alcohol, to remove any oil-residue left.
    Jun 2005
    Quote Originally Posted by number001
    at kung matagal na yung sticker, baka pag tanggal mo, halata dahil darker yung tint na covered nung sticker
    The safest and effective that I cna suggest is the mckenik that can bought in ACE hardware, I use it to remove the registration and license plate sticker annually.
    Quote Originally Posted by carlocaraddict
    soften it with baby/cooking oil or kerosene overnight then pwede nang kutkutin the following day. mas okey kung me plastic spatula-like ka. pangit ata pakinggan hth
    credit card na luma!
    Aug 2005
    hot steam water... tama si Otep!
    Aug 2005
    try using this
    can be purchased at tru value
how to remove an old conduction sticker?
