hi guys.. how can we paint (black) those chromed grilles? i was told that it can be painted but it will fade soon.. is there any way? thanks
i sand mo muna yung chrome, tapos put putty, tapos paint over it. siguro two coats of black plus one clear coat will do.
what part of the car?
pag chrome trimmings sa windows dont try na,
it will chip off agad.
pag yung mga iba,better sand it off with a good 600 grit,then
sand it again with 1000 na mabilis lang.
then prime it,then sand with 1000 just to remove the orange peel,
then paint it na with black.
dont put body filler/putty or it will get off agad dun sa surface since
we want it just black it,baka makitid yung surface it will result
to chipoffs.
this is the correct process. just remember to also clean the piece thoroughly with painter's solvent (lacquer thinner can work) in between sanding steps.
grills are notoriously difficult to paint because you have to sand every part of the piece, and there are many places that are hard to get to. but if you don't scuff up every inch, the paint won't adhere properly and it will eventually peel off.
id rather not paint it.
rock debris or even a fingernail will chip it,id bet even with primer.
there's an easier and much OEM look for you to get that black trim,
tried and tested for euro/usdm peeps who dull their chrome trimmings
with these black linings.
its a sticker that looks like an electric tape,
its flat black already and it will last long.
mine is 5years and going pa rin,ulan araw init pressure washer and
a lot cheaper to make IMO.
here's the pic.
HTH.![]()
a good one mr lexter.
hassle lang kasi seeing when it chips,since makitid yung area na ipapaint
mas safe na rin yung balot for me.
nice drop sir,pero mukhang may karga sa likod?![]()
* badbatz.carlo : nope bro,its a mixture of black paint and
an agent used para it will look like that,
RE on the sticker,i called out the sticker supplier.
out of stock nung flat,maybe you can find it on your local
sticker shop.
* sir meledson : yup.tama po kayo sir,most of the cars right now,
sticker na yung black part nila.even the new civic fd.
