Results 1 to 18 of 18
    Oct 2007
    Hi guys. Ask ko lang if it's okay to use quick detailing spray on windshield, windows? I usually dust it off first using my cali duster but some times kasi may mga water marks from the rain so i wipe it off pa with my MF towel na may binasa ko ng quick detailing spray.
    Okay lang ba 'to? Will it cause scratches or something? TIA!
    Aug 2010
    Quote Originally Posted by mad0307 View Post
    Ask ko lang if it's okay to use quick detailing spray on windshield, windows? Yes.
    Will it cause scratches or something? No.
    Pero nagsasayang ka lang. Just get a MF, wet it with water, wipe, dry.
    Oct 2007
    Quote Originally Posted by jhnkvn View Post
    Haha! Oo nga bro! I also did the wet MF thing pero parang may marks pa rin eh,that's why i also tried to use the QD on it.
    Aug 2010
    If then so, the watermarks are now a bit stubborn na.
    QD will work.. but it depends on what type. There are quick wax detailers such as Microtex 0Nanosliq and there are simple "cleaning" detailers such as Mother's Showtime.
    A better choice would be to purchase spray bottles that's dedicated for window cleaning. These usually have some chemicals to soften the sediments of rain/watermarks for easy removal.
    Oct 2007
    Thanks bro! Im thinking of buying those window cleaners nga
    Aug 2008
    I always use QDs on my glass. I like my cleaning solution to be a bit more lubricated than plain water (glass is harder than paint, but it is still possible to scratch it), and since I use a sealant on the glass, I want something gentler on the LSP than most window cleaners (which usually contain varying levels of isopropyl alcohol). You do have to choose the QD though - some QDs can streak more than others, and while this is not as noticeable on paint, it can be very obvious when seen through your windshield.
    Oct 2007
    Quote Originally Posted by umi001 View Post
    ^may i ask the brand of qd that you use? Have you tried the polyglaze glass cleaner?
    Oct 2011
    Pwede din pala QD sa windshield glass? I still use a separate glass cleaner.
    Sep 2010
    i used meguiars ultimate quick detailer once as lube for claying windows. nagkeclay ako nung body tinuloy ko na sa bintana.
    Aug 2010
    Quote Originally Posted by xwangbu View Post
    Yaman naman! Megs UQD pa ginagamit for the windows! :O
    Sep 2010
    ^once ko lang ginawa yun sir.
    Aug 2008
    I currently use Poorboy's Spray and Wipe on glass - it's marketed as having no gloss enhancers. Optimum No Rinse in rinseless dilution (1:256) works too, and Finish Kare's FK425.
    Feb 2011
    metal polish pwede ba pang linis ng glass
    Jun 2013
    rain x po mas maganda subok ko na
    Mar 2005
    Sakin may konting streaks na lumalabas sa windshield using ONR and DP Rinseless QD. Gamit na lang ako Megs Glass Cleaner Concentrate
    Oct 2007
    Madami din pala gumagamit ng QD sa glass. Kakatamad kasi to switch to glass cleaner pa. Hehe
    Mar 2005
    Pero when I use Duragloss Aquawax spray wax sa paint and glass surfaces, walang streaking.
    Aug 2008
    Quote Originally Posted by jmpet626 View Post
    Yes, the 1:16 dilution for either is a bit too concentrated for cleaning glass. I do better at 1:256.
    Have you used V7 on glass? How does it work? Meguiar's UQW also does well with regards to sealing glass, though I wouldn't use it to clean it.
Okay to use quick detailers on window?
