Results 1 to 9 of 9
- Sep 2007
- 146
December 8th, 2007 05:28 PM #1Hi! I need some help! I noticed a couple of days ago that there were some stains on my bumper. I thought it came from road tar or something like that. I tried to remove it using cleaner wax but it did not work.
Today, I brought it in for wash/wax/seal and they used kerosene to try and clean it up but to no avail... The car wash boy told me that this was caused by the oil from the tire dressing that I had used and could no longer be removed. May pag-asa pa kaya?
- Sep 2007
- 146
December 15th, 2007 03:09 PM #3Thanks for the reply. Already brought it to BB's, they were not able to remove it. I have also tried clay but it did not work. Will try rubbing compound next...
- 10,620
December 15th, 2007 03:18 PM #4easy lang sa rubbing remember its thins your clear coating and maybe the paint
December 15th, 2007 04:13 PM #5
tingin ko kinain na ng substance ang clear coat mo so pumasok na yan at umabot sa paint mismo kaya di matanggal..
- Sep 2007
- 146
December 16th, 2007 08:07 AM #6
December 17th, 2007 08:31 AM #8
Have it assessed first. If it's a paint defect take it for warranty repair. If it's something harsh like paint stripper or something then only way is to repaint that spot. Lastly, I took a look at the pic but did not see anything wrong with it. Maybe a larger size pic would help? That way we know what we're dealing with.
For oil dressing from the tire I simply use "soft" products like paint cleaner. When I accidentally sprayed some degreaser on the paint it slightly made some visible marks. Paint cleaner took it off immediately. Hopefully yours is still fresh...otherwise it may have eaten through the paint like somebody mentioned.
- Sep 2007
- 146
December 18th, 2007 12:17 AM #9Hi Washburn, I believe we have the same ride...
Hi mbeige, I don't think it's a paint defect, it was not there when I got the vehicle. I tend to agree with the info I received that it was caused by the oils from the tire dressing. Anyway, will also check with the dealer when I get the chance. Sorry about the pic, here's another version.
Monk-owned R53
