Results 1 to 6 of 6
    May 2007
    Mga bossing baka alam niyo kung anong swak na sukat ng gulong mejo duda kasi ako sa binibigay ng nung bibilan ko. Ito ung binibigay nya sa akin n size ng gulong 275/40r20. di ba masyado malapad yun para sa oto ko. Mazda tribute ung ride ko. suggest lang kayo kung ano mas swak. stock ng oto ko is 215/70r16. Salamat ng marami.
    hi sir,
    this site helps a lot.
    http://www.miata.net/garage/tirecalc.html
    re: your query, medyo tama naman ang reco sayo ng shop.
    stock specs:
    215/70/16
    diameter is 27.9 inches
    option 1:
    275/40/20
    diameter is 28.7 inches
    __________________________________
    best tire size so that diameter is still the same with stock is
    255/40/20
    diameter is 28 inches
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    May 2007
    sir thanks for the reply, very helpful one sir. More power to tsikot
    pattern kasi yang 245/40-20 sa 235/70-16 na OEM size sa states..
    masmalaki na kasi ung tires nila dun kaysa satin na 215/70-16 pa rin.
    eto ibang sizes..
    235/65-17
    255/55-18
    255/45-19
    245/30-22
    kasya kahit 285 width na 18 inch rim. di sasabit..
    gawin mo.. hanap ka na lang ng Service Advisor na mabait. Program nya ECU or VIN ng tribute mo to compensate for the larger tire size. Para matanggal speedometer error. May kaibigan ako sa fordclubphilippines ganyan ginawa nya. 255/55-18 nilagay nya.
    Speedometer: 95.9 km/h [vs. 100 km/h - actual]
    Speedometer Difference: 4.272% too slow
    Diameter Difference: 4.1%
    maliit lang naman difference..so neglible naman.
    check these sites for more info:
    www.escape-central.com
    http://www.tirerack.com/index.jsp
    http://www.1010tires.com/TireSizeCalculator.asp
    Feb 2007
    hi kiper, i am Arj in FCP. can your friend refer me to this service advisor na mabait?
    i installed bigger tires on my escape. now, my speedometer is now 5% slower
    May 2007
    pros and cons ng lifter or highered? My naka try na ba ng ganto sa suvs? gusto ko sana kasi tumaas oto ko after magpalit ng mags. Thanks
tribute rollin on 20's
