Results 1 to 6 of 6
- May 2007
- 26
August 19th, 2007 11:20 PM #1Mga bossing baka alam niyo kung anong swak na sukat ng gulong mejo duda kasi ako sa binibigay ng nung bibilan ko. Ito ung binibigay nya sa akin n size ng gulong 275/40r20. di ba masyado malapad yun para sa oto ko. Mazda tribute ung ride ko. suggest lang kayo kung ano mas swak. stock ng oto ko is 215/70r16. Salamat ng marami.
August 20th, 2007 02:22 AM #2
hi sir,
this site helps a lot.
http://www.miata.net/garage/tirecalc.html
re: your query, medyo tama naman ang reco sayo ng shop.
stock specs:
215/70/16
diameter is 27.9 inches
option 1:
275/40/20
diameter is 28.7 inches
__________________________________
best tire size so that diameter is still the same with stock is
255/40/20
diameter is 28 inches
- May 2007
- 26
August 22nd, 2007 03:07 AM #4
pattern kasi yang 245/40-20 sa 235/70-16 na OEM size sa states..
masmalaki na kasi ung tires nila dun kaysa satin na 215/70-16 pa rin.
eto ibang sizes..
235/65-17
255/55-18
255/45-19
245/30-22
kasya kahit 285 width na 18 inch rim. di sasabit..
gawin mo.. hanap ka na lang ng Service Advisor na mabait. Program nya ECU or VIN ng tribute mo to compensate for the larger tire size. Para matanggal speedometer error. May kaibigan ako sa fordclubphilippines ganyan ginawa nya. 255/55-18 nilagay nya.
Speedometer: 95.9 km/h [vs. 100 km/h - actual]
Speedometer Difference: 4.272% too slow
Diameter Difference: 4.1%
maliit lang naman difference..so neglible naman.
check these sites for more info:
www.escape-central.com
http://www.tirerack.com/index.jsp
http://www.1010tires.com/TireSizeCalculator.asp
August 22nd, 2007 09:44 AM #5
hi kiper, i am Arj in FCP. can your friend refer me to this service advisor na mabait?
i installed bigger tires on my escape. now, my speedometer is now 5% slower
- May 2007
- 26
August 29th, 2007 02:11 PM #6pros and cons ng lifter or highered? My naka try na ba ng ganto sa suvs? gusto ko sana kasi tumaas oto ko after magpalit ng mags. Thanks
Mazda 3 is incredibly tempting, unfortunately the hybrid is not included in the coding exemption...
All New Toyota Corolla Cross
