Sobrang OT na tayo (branching out from the engine wash topic though)
but what is VTVM?
dumating na yung cochemax. walang beading effect yung built-in "wax". also the foam isn't as good as MTXshould've gotten the high foam version instead. cochemax is an ok brand. their degreaser is pretty good
check the other sellers. there are short guns available in various connector types so just pick one that fits your existing hose. but apparently the most common type is the m22 x 15 i.e. the threaded part is 22mm while the smooth inner bore is 15mm inner diameter. you might want to migrate all your hardware to this size
Peeps tanong naman - mas matibay ba yun yellow na pressure washer hose? planning to get one this coming 8.8 sale
Thanks bro. Bought this K variant connector -
https://www.lazada.com.ph/products/m...21705140.html?
kaso bumibitaw, hindi snag fit ang Lotus ltpw1400x hose, meron pala 2 klase ang quick connector: 4 and 5 series
https://www.lazada.com.ph/products/p...40436239.html?
Tama ba dapat ko bilin is 5 series? or better ba kung buy your same swivel connector tapos threaded hose? di nga lang quick-connect/disconnect ...
