sorry. . i'm bored to death sa shop. . decided to share my knowledge on changing our stock shifters to aftermarket ones.. .mali ang nagsabi na hindi pwede. . whoever that was didnt have the creativity nor the passion to modify of what makes us ingenious(rong slepping?) pilifinos different from the world. . ok. . .masyado na ako pakyut. .
i am one of the unlucky few(?) to own or rather drive an a/t familia .. ala..dami magagalit. . since swapping the a/t to a m/t is quite difficult and cost prohibitive, i just settled for an aftermarket shifter (momo automatico).
removing the stock one is quite easy. . just a couple of screws. . one at the side and one infront of the handbrake. . removing it completely would mean cutting the HOLD button wires (oh no! walang hold button yung momo automatico! ala i-spank na ako ng papa ko!) errrr...madali lang yun. .
anyways, the momo shifter doesnt fit the stock shaft so i visited c.a. roque at timog near gma7 to have the shifter hole widened by about 2mm .. service cost 750 petot..ouch. .
so, ok. pasok na .. pero ang panget! sobrang haba ng shaft! yaaaaaak! hmmm..i then visited filmar at katipunan and rod (the man) used a metal saw to cut the shaft approximately 1 1/2 inches (stock shifter would be a biatch to put back by doing this) same was done for the thinner bar in the center. .
end product is this. .
comment ni 323f a.k.a. mzrz6 dapat mas maikli pa. . i-DIY ko na lang pag may oras
but WAIT! pano yung HOLD button! ala! naku! spank na ako ni papa! huhuhu
what i did was find a button na maganda but should not be the locking type (parang pang arcade game dapat) i found a nice big red one at my friendly neihborhood DEECO .. 2 for 150 petot. . the button is a bit on the loose side so i opened it up and swapped the spring to a stiffer one from those extra signal light sockets that i have lying around .. the button fits snugly sa rectangle sa may handbrake. . all i need now is something to cover the sides para flush and clean .. i then found an "extra" DVD case and cut it to fit ..
at the other side of the handbrake lever, i also put a cut off switch for the a/c .. the switch was also purchased at DEECO and surrounds were also the cut up DVD case. . wiring was routed behind the original a/c switch. .
TIP: always leave A/C switch on pag ipapadrive sa iba .. . me mama told me hindi daw malamig A/C ni wen
end product was . .
looks neat? check.
looks stock? check.
do the switches work? siyempre. of course. then all of this is a waste of time then.
smile on my face? check.
