Results 1 to 9 of 9
    Feb 2009
    good day mga tsikoters, newbie lang ako dito.. tanong lang po, kasi yung toyota corolla ng pinsan ko, pinagamit saken para daw masanay ako mag drive. kaya lang newbie pa din ako mag drive, medyo masikip parking dito samen. ilalabas ko sya ng bahay nang pa-reverse. kaso di ko natancha, dumikit sa wall yung likod nya. light scratch lang naman sya kaya lang halata kasi kulay red yung kotse. ano kaya magandang remedyo dito? thanks in advance..
    Mar 2004
    Hard to tell.
    First, nararandaman mo na sa daliri mo yung light scratch na yon? Try running your fingernail along or across the scratch. If the scratch catches your fingernail, or worse, if you can feel the scratch from your fingertip, hindi na siya light scratch. Major scratch na yan.
    If you can't feel the scratch with your fingernail, then light scratch nga yan.
    For light scratches, you can completely eliminate them by using a good scratch remover. Use Meguiar's ScratchX or something equivalent.
    For major scratches, you will never be able to completely eliminate them. You can however, minimize them to be barely visible using a good scratch remover. If you're lucky, you can minimize that scratch to a point where only you can see it.
    Feb 2009
    thanks to you ess.. base sa sinabi, ang findings ko is light scratch nga lang sya.. mga magkano kaya yung meguiars scratchx? salamat ulet..
    Mar 2004
    The last time I bought a tube of ScratchX, nasa 700php ata. But that was 3 years ago.
    You can get them at any Blade outlet. A bit pricey, pero tatagal naman siya talaga (unless palaging nagagasgas yung kotse..heheh).
    You may also want to check out other scratch remover brands like Mother's, Eagle1 and Turtle Wax.
    Feb 2009
    salamat bro... ngayon alam ko na... medyo mahal pala no.. baka meron yung ibang tropa ko.. hingi na lang muna ko, maliit lang naman yung scratch.. sayang kasi kung bibili ako ng bago... iingatan ko na talaga magasgasan para di mapagastos.. hehe..
    Mar 2004
    Quote Originally Posted by the_transporter View Post
    May kamahalan talaga siya, pero sulit talaga siya. Parang ayaw nga maubos yung akin eh... Pinapahiram ko na nga sa mga office mates kong nagasgasan din.
    Yeah, check mo mga tropa mo kung meron sila. Konting konti lang kailangan mo. Siguro a 1-peso sized drop should be enough to treat a very minor scratch.
    Jan 2009
    Quote Originally Posted by ess View Post
    where are those Blade outlets located? xenxa na newbie pa po.new car owner. thanks
    kung maliit lang yan paps,daan ka na lang sa shop,
    we'll remove it na lang at no cost.
    (basta maliit lang ha)
    help ko sa nagaaral magdrive.
    * the_transporter : this is your guide.
    www.patpaint.tk
    09155057705 09222255122
    hope this helps bigtime.
Light scratch, ano po remedyo?
