Originally Posted by
mackkcam
anu ung AFAIK? - As Far As I Know.
yep, i would lower my ride, just for 1.5" lng, may sounds, malakas nga ang kalampag sa Back pero di obvious, kc malakas sounds eh, haha
ah ic, so hindi na kelangan ung shock mounts?? pero pag may tama na palit na rin, hehe. Normally, what you replace are shock mount bushings or bearings. Depende sa shock mount mo yan. But the entire mounts are not replaced, unless may biyak na.
Anung Baso? - baso is where the shocks and the springs settle. yun yung parang sumasalo sa shocks/springs. kung wala yung baso, hindi magsesettle yung height ng car. ung lifter? a lifter is some sort of rubber stopper that you put between the springs/shocks and the shock mounts. the purpose of this is to lift the car. kung ung lifter, uu, wala pang 1" ung gap nya sa tire, pero hindi naman sumasayad sa tire ung lifter kahit sa humps or what, cguro 3.5" finger gap xa, using 195x15x50 tires (will switch to x55)..
Paraut gas shocks 2,350/pc
spring coil - unknown pa ung brand pati price - 600-700, no lifters
shock mounts - 650 ata/pc
Mura na ba yan or ok na yan? based on the price above, the shocks is on the normal cost. yung spring coil, i think its a replacement stock coil. hindi lowered yan, imho. sabi kc may discount na ako eh, tyka ok na ba yang mga parts na yan, any suggestion sa spring coils? ung brand, for lowering, ayaw ko naman kc ng Putol coil eh, thanks
