I suggest doing it by hand. Soften the sticker with water, or soap and water, or shampoo, then peel off with fingers or a plastic thingie. Adhesives can come off easily, but a scratch might stay forever.
kung pang sticker lang sa windshield meron sa ACE hardware sa cutters section... blade sya with neon green or neon pink yung handle. syempre yung green ang binili ko. :D
Bili ka na lang ng 3M sticker/adhesive remover na spray...
Kung nagtitipid, use hot water (galing sa airpot) and a sponge na pangbabad sa sticker, ito yung ginamit ko pantanggal sa LTO conduction sticker. Tanggal agad sya, no scratches....
Originally posted by baiskee kung pang sticker lang sa windshield meron sa ACE hardware sa cutters section... blade sya with neon green or neon pink yung handle. syempre yung green ang binili ko. :D
The principle is to apply heat to the sticker so that the gum will melt. Thereafter, peeling off the sticker becomes much easier. If applying hot water intimidates you, why not use a hair dryer that's on hot air mode?
hmm..so i can use sponge soaked in hot water to remove the lto sticker? im planning to have the front windshield tinted kasi but the lto sticker is there na..
unless you plan on driving _only_ during the day, dont have it done pare. tinted din yung windshield ko dati; light lang pero ang hirap pa din mag-drive sa gabi. yun, pinaalis ko.
yun bang sticker lang ng lto sa windshield ang problem mo? don't use scraper, sigurado puro scratches windshield mo nyan. malambot lang ang automotive glass madaling magalusan yan pare.
ako i just peel it off with my fingernails. plastic naman yung sticker so madaling i-peel off, patience and perseverance lang ang need mong tools dyan. tapos yung maiiwan na glue, wd40 lang katapat nun. just wet the area with wd40 then just rub it off with a piece of rag.
gaya ng sabi ko una, patience and perseverance lang tools na need mo. anything else will result in a scratched windshield.
*roninblade
di naman manyak tint..light black lang siguro ng 3M or sunguard..just to block off enough UV rays in the late mornings and early afternoons..
*yebo
actually i think i will going to wait na lang till next year?? (gulp!) pag saktong i-re-register na yung car then baka di ko na lang ikabit yung lto sticker (pwede ba yun?)
mukha ngang mahirap tanggalin at hindi pwedeng basta-basta na lang...
yan din po ang problem ko ngayon...i haven't been able to put my LTO sticker on kse nga tinted ang windshield ko. well, sabi nila ok lang daw na d ikabit, basta itago mo lang...can anyone here validate that?
