Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    does anyone know how to remove a car sticker completely without ever having doubts if marks will be left behind?
    boss otep: may sticker ka ba nung sa ust? if meron, pano mo naaalis yun completely? yung sakin kasi, parang sobrang dikit na nung sticker eh. help po....
    Heat the sticker to soften adhesive, you can do this with a hot air gun or hair blower or just leave the sticker under the sun for a couple of min.
    Peel off the sticker as slow as you can, as much as possible buo yung sticker, if kaya then madali lang, clean the residue off with adhesive remover (even WD40 will work)
    Kung di maganda yung sticker at napuputol, a really thin flat blade would help.
    Oct 2004
    Try placing a rag soaked from hot water on the sticker for 3 mins. The sticker should peel off easily after picking on edges.
    Jan 2003
    me nabibili sticker remover na liquid sa ace hardware
    i do the other way around. instead of heat, i get ice cube, then glide it on the sticker for a few minutes, then peel it off, kasama na pati adhesive sa sticker.
    Aug 2003
    Quote Originally Posted by buknoy2002
    mahal yun! lighter fluid works just as well. i always use lighter fluid to take decals off glass.
    Oct 2003
    ako i used steam to remove my stickers..had to do that prior my full windshield tinting..didnt know pwede pala ice cube? ma-try nga next time hehehe
    Quote Originally Posted by zechs
    make sure that your car is on the shade para di masyado mainit windshield and to save by just using 1 cube. once you get a good grip on the edge of the sticker, slowly pull it off. Solved!
    I use a blade to remove the UST sticker. Heat helps, too.
  10. #10
    or you can use a plastic card like a used-prepaid or credit card then slowly peel of the sticker. Warm the sticker using rag dipped in hot water.
    Sep 2004
    apply heat to soften the adhesive ...
    use thin blad to pry the edges ...
    patience para masigurong buo mo matangal ...
    leave the car under the sun, use a thin blade. dunno if it would leave a scratch though. been doing this for years, wa naman..so far
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Nov 2003
    After I apply heat, I use my trusty Swiss Army knife to peel off the edges. Never had scratches. Never had problems.
    Mar 2005
    Lighter fluid, maraming gamit yan
    Oct 2004
    Tama. Pwede ka pa mag-yosi after removing the sticker. Hehe..
    Oct 2003
    just used the "ice cube" method today..works well..peeled off my lto sticker in one pull..hehe nice tip!
    thanks guys... hehehe... ngayon lang ako nakapagpost ulit...
    Feb 2005
    pinapaarawan ko kaso naging brittle naman yung sticker and mahirap alisin lalo. sobrang tagal na kase. hmm try ko nga ice cube...
    Oct 2003
    yeah try it..ok yung ice cube method..if you got a good grip of the sticker na, madali na lang yan..(this is for the lto sticker, in my case) pero pag sobrang tagal na ang sticker, di kaya i-peel-off coz nasisira siya kaagad.
    Nov 2003
    If I may digress a bit. How does one remove a Conduction Sticker? This has been on the car since it was bought in 1995. Ten years na. I tried prying the edges with a blade or a knife, pero mukhang hindi kaya.
how to remove a car sticker completely and neatly...
