Results 1 to 10 of 27
April 29th, 2005 07:07 PM #1
does anyone know how to remove a car sticker completely without ever having doubts if marks will be left behind?
boss otep: may sticker ka ba nung sa ust? if meron, pano mo naaalis yun completely? yung sakin kasi, parang sobrang dikit na nung sticker eh. help po....
April 29th, 2005 07:55 PM #2
Heat the sticker to soften adhesive, you can do this with a hot air gun or hair blower or just leave the sticker under the sun for a couple of min.
Peel off the sticker as slow as you can, as much as possible buo yung sticker, if kaya then madali lang, clean the residue off with adhesive remover (even WD40 will work)
Kung di maganda yung sticker at napuputol, a really thin flat blade would help.
April 29th, 2005 08:08 PM #3
Try placing a rag soaked from hot water on the sticker for 3 mins. The sticker should peel off easily after picking on edges.
SiRaNeko
- Jan 2003
- 973
April 29th, 2005 08:31 PM #5
i do the other way around. instead of heat, i get ice cube, then glide it on the sticker for a few minutes, then peel it off, kasama na pati adhesive sa sticker.
April 30th, 2005 01:33 AM #6
ako i used steam to remove my stickers..had to do that prior my full windshield tinting..didnt know pwede pala ice cube? ma-try nga next time hehehe
April 30th, 2005 01:52 AM #7
I use a blade to remove the UST sticker. Heat helps, too.
April 30th, 2005 01:55 AM #8
or you can use a plastic card like a used-prepaid or credit card then slowly peel of the sticker. Warm the sticker using rag dipped in hot water.
April 30th, 2005 02:27 AM #9
apply heat to soften the adhesive ...
use thin blad to pry the edges ...
patience para masigurong buo mo matangal ...
April 30th, 2005 02:34 PM #10
leave the car under the sun, use a thin blade. dunno if it would leave a scratch though. been doing this for years, wa naman..so far
