Originally Posted by
lm723
I'll have my car repainted in the coming months..
Orig paint pa din ung nasa car, medyo faded na sa tagal and i got a suggestion from one of my friends na lihain na lang nang todo and wag i scrape tutal orig paint pa.
And process lang kse na alam ko is..
- Scrape or Liha scrape to metal
- Latero if may gagawin
masilya or automotive putty application, then liha
apply ng sealer
- Primer
- 1st coat of paint colored paint
- 2nd coat of paint same color paint- shempre
- -last part, if desired, clear coat acrylic for a glossy finish
- buffing
- waxing to protect the clear-coat topcoat
ilang coat po ba gagawin? and usually ilang liters ma uubos? depends on the size of your vehicle, mahina na ang 1 gallon
Considering DUPONT or PPG, which is good? both brands are good. try mo rin nippon paint if available
And, usually saan meron po nito? I mean, mas mura ba kung ako bibili nang paint and dalin ko na lang dun sa shop? or let the shop handle it.
dami paint centers catering to automotive paint. hanap ka lang, usually parang hardware yan na dediated sa paint. pintura lang binebenta nila at may signboard naman sila na "Paint Center". meron din silang parang brochure ng mga common paint colors ng mga kotse of various models. canvass ka muna, then go to your suking pintor/latero then compare prices
May option pa kse ako as of this time (canvass and research pa kse), but i rather let the shop do all the talking sa supplier nila.
if you trust your latero/pintor well enough, you can let him do all the canvassing. discuss mo muna sa kanya kung ano gusto mo gawin. daanin mo sa diplomasya para ayusin nya trabaho.
