Results 1 to 6 of 6
August 31st, 2005 05:58 AM #1
i dunno how it happened but nakita ko na lang kanina na may tagis yung right rear door ng ride ko. napakababaw lang naman at di nayupi yung metal but the problem is, bumakat yung white paint (ng nakatagis) dun sa blue paint ko.. it's about 6" long and 0.5" wide.. para tuloy nagkaroon ng white stripe yung door. tried to remove it by kerosene but ayaw maalis.. baka pag ginamitan ko ng thinner ay mamuti yung paint. pano ba matatanggal yun ng di masisira paint ko.
August 31st, 2005 07:58 AM #2
have you tried 3m swirl/scratch remover? pagnatanggal yan e magkakaroon pa rin ng scratch yung paint mo.. kung marunong kang gumamit ng rubbing compound kayang kaya tanggalin yan bosing tapos wax mo yung oto mo
August 31st, 2005 06:12 PM #5
any form of abrasive will work, from compound to sandpaper depending on severity.
September 1st, 2005 03:43 AM #6
brought the car kanina to a painting shop to ask for the rubbing compound pantanggal nung paint. baka daw di ako sanay gumamit nun kaya they offered to do the job. tanggal na ngayun yung white paint, winax pa nila ng konti. parang walang scratch na nangyari.. cost me 200 bucks plus 50 tip..
THANK YOU GUYS for all your inputs...
here's the pic ng scratch..
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
