Results 11 to 14 of 14
- Jan 2003
- 62
January 10th, 2003 01:07 PM #11..pahabol lang:
I did the following on my father's surf recently: (The stepboard is aluminum with grooves.)
-Process 1: Used EO-A2Z All Wheel Cleaner on 1/3 of the stepboard and just hosed it off. Ok naman, looked clean and bright. Did a second pass of EO-A2Z and used a soft brown (local) scrub before hosing off. Cleaner, of course, but no spectacular improvement.
-Process 2: Used Armor All MPC on 1/3 of the stepboard with water and scrubbed also. Came out with almost the same result as first process.
-Process 3: Used Tide and water and scrubbed again on the last part, hosed off. Not a far cry from the first 2 results.
Conclusion: I will stick to tide and water if and only if the dirt or grime will not be removed by water and scrub alone. Kasi for me no spectacular difference with the different products e. For maintenance, water and light scrubbing will do for me. For konting "show," will use use either of the first 2 process, whichever is in my reach at the time.
Theveed is right with the polisher, its the only thing that will bring back the "new look" talaga.
I think the stainless ones will need extra attention, and it will be more fun and rewarding to detail. While the aluminum ones look great already just by being clean. Although a little application of AA-Low Gloss on the inner, vertical part of the aluminum stepboard which faces the "audience" will be a plus. Konti lang ha, anyway it won't last that long kasi di naman maaabsorb.
Note: I did the tests so I'd know what to do and what I need in the future. Light scrubbing lang for all processes.
Opinion ko lang naman...
[size=18]carn vice[/size]
January 10th, 2003 02:20 PM #12
teka, bat nagdouble post tapos Dianne ang pangalan ng 1st post ni Ogie?
Weird bug..
BTW, I found out something cool the other day... I sprayed some APC+ sa muffler ko (stainless) na super dumi and black na... then got a loofah pad (yung pangligo, pero flat na parang patty) and used that to scrub... Hanep, 2 scrubs lang naging kulay bakal ulit muffler ko... hehe... It's not as abrasive as a steel wool.
- Jan 2003
- 62
January 10th, 2003 02:51 PM #13Yup, when it happened I noticed above that "Logout [ Dianne ]" was displayed, although I had to login naman to reply.. weird. So I re-posted, but had a hard time in the process, oks lang naman.
Okay pala loofah, hehehe! Arbor ko nga sa wife ko -kung papayag!
[size=18]carn :lol: vice[/size]
January 11th, 2003 01:47 AM #14nagmumukha raw
astig yung CRV at Adventure
Siguro yung spare tire cover ang next kong tatanggalin.
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
