Results 1 to 5 of 5
    Dec 2009
    Help po car afficionados.. I used the Formula1 carnauba step 3 wax but cannot remove the swirl marks left by the wax. Btw, I used micro fiber towel to polish but to no avail. I spent several days already buffing to polish the same using mf towel and used even wet pranela to remove it, it was lessened but not totally. What is the correct way of applying and polishing using this product? Your reply is very much appreciated. Thank you.
    Mar 2005
    Kung magtatanggal ka ng swirls by hand you should use Meguiars Swirl X and a foam applicator pad. Microfiber towels is used only to buff off the polish afterwards. Formula 1 step 3 is not designed to remove swirls.
    How To Remove Swirls By Hand by Mike Philips
    http://www.meguiarsonline.com/forums...&threadid=7011
    Dec 2009
    Quote Originally Posted by jmpet626 View Post
    my mistake in using the word "swirl marks" it should be marks left by the wax. yun po ung natuyong wax na hindi matanggal ng hand buffing using the microfiber towel. nahihirapan po akong tanggalin kasi kahit ilang ulit ko nang pinupunasan. natatakot din ako sa sobrang pressure sa pag rub baka mawala ang clear coat. rotary na po ba kailangan dun or ipa detail ko na lang? thanks po.
    Aug 2009
    try misting some water and using MF towel to remove it, if not try some Quick Detailer to remove it, Formula 1 Step 3 does really have the reputation of being rock hard to remove so you have to apply it really sparingly and as thin as possible or thats what you get.
  5. #5
    sir i checked the site and they used scratchX. so, the swirlX is the lesser aggressive product?
Help.. what to do to remove car wax swirl marks
