Results 1 to 17 of 17
    The original Grit guard was over my budget so I made one that would fit my budget.
    Id like to share the DIY Gritguard that I made. All it took was a rubber mat, a utility knife,and 5 minutes. Cost of the rubber mat was 79.95/pc.
    Hope it works. Ill post the photos of the accumulated grit after washing my car.
    For anyone who've done this, is it as effective as the original design of the grit guard?
    Rubber Mat - cost P79.95/pc
    Measured the diameter of the bottom of the bucket. Then cut the mat into a circle
    side view of the mat, IMHO, this is quite thin so i used what remained of the mat and placed it at the bottom
    Used the remaining pieces from the original mat
    2 layers - just to be sure
    Last edited by watusi; September 2nd, 2010 at 02:08 PM. Reason: revised some text and changed 1 photo
    Nice idea man!
    From the cross section, I think the mat height, although thin, is good enough as the bottom side acts as baffles from stirring up the water below it. I do suggest a clear pail rather than the red one you have to see how effective your grit guard is.
    Mar 2005
    Nice DIY! Pwede din kaya yung casing ng electric fan or yung plastic na pang takip ng ulam? Kaso need ng mas malaking bucket.
    Jan 2009
    simple but doable. nice one!
    Sir you are a genius!
    Jan 2008
    nice idea... pero mas maganda yung foam wash para hindi na yuyuko
    Quote Originally Posted by Mguy View Post
    Nice idea man!
    thanks!
    ok, i'll try looking for a clear pail.
    Quote Originally Posted by jmpet626 View Post
    ok din yung pang takip ng ulam! dual purpose pa
    thanks idol! congrats BTW on the contest!
    Im saving up for that haha
    I wonder if we can DIY a foam gun
    Quote Originally Posted by OldSchoolHack View Post
    thanks! hope it works as well as the original ones
    Mar 2005
    Meron sa autobisyo na gritguard last time na nag inquire ako 800 each..
    Mar 2004
    Thanks for sharing! This is great.
    By the way, does having a grit guard eliminate the need to use the two bucket method?
    Quote Originally Posted by ess View Post
    To be on the safe side, I still use 2 buckets with gritguards on both buckets.
    Mar 2005
    yung iba pa nga 2 grit guard per bucket. Nakuha kio na yung gritguard ko and medyo bulky nga siya
    Jul 2013
    Ayos, creative solution
    Last edited by iam_Chris; August 24th, 2013 at 03:27 AM. Reason: extra word removed!
    Jun 2013
    Quote Originally Posted by iam_Chris View Post
    Agreed. Will make one next week!
DIY Gritguard
