Hello. I read somewhere that you could retrofit a KP600 to use the 3M waffle pads for wax application.
Im very dissatisfied with the applicator pads which came with my polisher.
My question is, where to get the velcro? Im aware that you can get these velcro strips at national bookstore, but i dont really want just velcro strips. I want to get the circular velcro hook thingie which covers the whole contact are. is this locally available and where? Or where can i get big pieces of velcro?
TIA :beard:
dude pare may tawag diyan back up pad!
dun mo kinakabit ang foam pad
meron ako dito dude
BIGAY ko nalang sa iyo, libre mo ako lunch
3M Perfect Back Up Pad Part No. 051131-15718
DEAL?
and also mayroon akong 3M products maski at cost ko na lang bigay sa iyo
3M multi purpose cleaner concentrate
3M Perfect it II Rubbing Compung
3M Perfect It III Machine Glaze
3M Professional Grade Liquid Wax
That backup pad (05718) won't work with the KP600. That's designed for rotary polishers like the Makita 9227C and other rotaries that share the same spindle size. People usually buy these backup pads pag yung rotary nila ay walang kasamang velcro backing pad (like the B&D rotaries). Si theveed though, baka magamit niya yan.
There isn't really an advantage to attaching a whole circular sheet of velcro as opposed to just attaching it as strips. Of course, it looks cleaner that way, pero just as long as the polishing pad attaches firmly and does not fly off, you're all set.
Kimps:: Thanks for the offer pre, kaya lang, like what irmscher said, di pwede sakin yan :mad: Sige pre, if i ever need 3M stuff, sayo ako kukuha. Medyo stocked pa ako e.
irmscher:: thanks for the reply dude! i just didnt feel comfy enough with the hook strips, kinda looks flimsy if you think of it. You own a KP600, if i may ask?
kim:: bad trip nung isang araw, ginanahan akong mag rubbing (by hand), tapos, di ko napansin, konti lang nalagay kong gaas. hayun, kalbo pintura ko sa quarter panel! hehehe Buti na lang hindi tinamaan yung "intercooler turbo" sticker. but anyway, oks na ngayon. buti na lang may talyer tito ko hehe :D
I own a KP600 and I've actually retrofitted it to accept the 3M waffles. The red velcro strips available in the bookstores will do the job just fine. If you wnt to further secure the velcro strips to the rubber backing, you can spray it with some 3M adhesive.
pajerokid,
If ur intrested, m selling my 3m waffle pad brand new, ive got a piar of these, 250 lang each. nde ko pa nagamit kahit isang beses. btw, i own a KP600 b4.
you can buy good velcro in any textile shop in the malls, they have more sizes to choose from. The KP600 can't use a backing pad since it doesn't have a threaded attachment.
Originally posted by pajerokid Kimps:: Thanks for the offer pre, kaya lang, like what irmscher said, di pwede sakin yan :mad: Sige pre, if i ever need 3M stuff, sayo ako kukuha. Medyo stocked pa ako e.
Nope. Pero bacon and several other PAD guys own a KP600 and the velcro thingie has been discussed before na kasi sa PAD forum.
revoGSX: Ok na yan, bought mine from a friend for around 2400, that was last year. Get some velcro strips from ace, idikit mo lang sa likot ng rubber backing plate your all set. Hanap ka na lang ng mga pads, may nagbebenta ata sa pinas detailing. Try emailing reno*vasia.com
