just this morning because of "onyok" binaha auto ko. i overslept and baha na pala sa kalsada. yung baha abot sa lower portion ng doors! water went inside my car siguro mga 1 1/2 inches high sa flooring!
wat do i do? what do i have to inspect or check? help pls!!! i have an amp and a cd changer installed sa flooring. dinisconnect ko lang hindi ko nga alam kung na damage na. all i did was remove the seats and the carpet. yung flooring pinatuyo ko and vacuum the water inside. help pls. tnx.
immediately open those electronics and dry them up using a hair dryer ... the amp isn't very critical and would likely work again ... the cd changer is quite sensitive due to its optics and electromechanicals but if you could manage to have it thoroughly dried, cleaned and lubricated, it may work again
unfortunately, if corrosion have already started before you dry up, the damage would require more repair work
